Hello,
I have a vertical layout and a horizontal layout. Bothe have Identical MSO that have text blocks. How can I link the the identical text the the two text blocks in each of the MSOs?
If you have InDesign CS6, you can use the Content Collector tool to set up a link between the layouts. With InDesign CS5/5.5, it's more difficult, but you link text with a workaround. See this article:
http://blogs.adobe.com/indesigndocs/2010/12/sharing-text-between-two-i ndesign-documents.html
So Is my workflow wrong....
I have been setting up framework for each format in masters...
then go back through and drop in content to each one of the formats
your saying I should compleate one finished doc and alternate each new format.
But then you have to split your alternate layout in to seperate documents when it comes to build the folio? to have the correct file structure?
