Folio not updating
Aug 8, 2012 6:59 AM
Hi there
Despite updating, then even deleting and re-uploading, a certain folio won't update on the view or the folio producer webpage.
Is this a known issue or is there possibly somethign I might be doing wrong? All seems very straightforward but no dice!
thanks!
Steve
    Aug 8, 2012 8:36 AM   in reply to SteveLunny
    Can you send me your productID to roche@adobe.com? Also, please let me know the publication status of your folio. I can look into our backend and see if there's a problem.
    Thanks.
    Aug 8, 2012 1:23 PM   in reply to SteveLunny
    I'm not exactly sure what you're describing, so forgive me if I'm not solving your problem with this advice ...
    The panel has a hierarchy of document menus that go "All Folios" -> "Articles" -> "Layouts". If you click through to the "Layouts" view and add a document there, it should either add a new orientation or replace an existing one, depending on what's already there.
    If I'm completely misunderstanding your question, let me know and provide more insight to what you're seeing.
    Thanks.
    Aug 8, 2012 2:00 PM   in reply to SteveLunny
    Thanks for the explanation, very helpful.
    I'll have someone look into the issue and he will follow up. This should be pretty easy to explain, I'll make sure someone gets back to you soon.
    Thanks again.
    Aug 8, 2012 2:52 PM   in reply to jamesroche
    OK. I figured it was easier to just try the repro than it was to describe it to someone else, so I tried it myself. That said, I didn't encounter the same problem.
    Here's what I did:
    1. Login to Folio Producer (FP) using an account with a number of existing folios
    2. Create a new folio in Folio Builder Panel (FBP)
    3. In FP, open existing folios and use the 'Copy To' command to copy articles into the new folio. (repeat 3x)
    4. Return to FP Organizer
    5. Open new folio
    6. Edit metadata, title, and TOC image on one of the articles
    7. Return to FP Organizer
    After running through this, I did not see any unexpected placement of edits I made in step 6.
    Can you verify my workflow and correct me if I'm not reflecting your guidance correctly?
