It happened two days ago only, flash player fails to run when brwsing internet content. I use IE 9, I didn't install any new program, the same anti-virus/security setup since 1 year. I re-installed Windows 7, but the problem persists.
I also tried all the recommendations in other discussio, but nothing worked. Evedrytime, I need to uninstall, and then reinstall Flash.
Any final remedy for this ordeal?
It sounds like you might be running into a permissions issue. Could you please try running through the steps listed in this FAQ:
Can you clarify what you mean by "fails to run"?
a message/box "You don't have flash. Click here to load flash" or " you may need to upgrade your version of Flash". When I try to upgrade or reinstall, installation fails "Newer version already installed". I must uninstall first in order to have successful installation.
I have to repeat this after the computer is ON from a shut-down, logout, or Sleep.
Next time after you restart your computer, can you check if Shockwave Flash is still enabled? (See http://forums.adobe.com/thread/885448)
This is what I have
Name: Shockwave Flash Object
Publisher: Not Available
Status: Enabled
Thanks Chris, it resolved it; I restarted it more than 5 times.
I appreciate if Adobe, or Microsoft, come up with a patch/update to resolve this for all
Thanks for the update. We're working on it.
