Im looking for Sass extension  Dreamweaver cs6
Aug 8, 2012 3:09 AM
Tags: #css #postprocessing #css3 #compass #dreamweaver_cs6 #sass #scss
I would like it the Sass  in the Dreamweaver to be useful integrating. (extension(*.scss) and language support) [Im working PC]
Can somebody help me?
    Aug 8, 2012 11:36 AM   in reply to Typo83
    Not aware of an extension for this, but here's a blog post by Greg Rewis with info about how to add support for SASS in Dreamweaver:
    http://blog.assortedgarbage.com/2012/03/using-dreamweaver-with-sass-an d-less/
    Sep 7, 2012 7:32 AM   in reply to Typo83
    Built an extension to do this:
    https://github.com/adamcoulombe/dw-compass-codehints
    It also adds code hinting for many compass mixins...
    Sep 14, 2012 12:26 PM   in reply to Typo83
    Removed the ZXP package, just install using the .mxi . If it gives you warnings about not being signed just say ok and ignore them and it should work. I have tested on mac and PC using DW 5.5
    Sep 20, 2012 12:42 PM   in reply to Carey Burgess
    Can I ask you for some assistance.
    I tried to follow the assortedgarbage tutorial, but I was only able to find the files listed in the applications folder, and nothing in the ~username/Library/Application Support/Adobe/Dreamweaver CS5.5/en_us/Configuration or any other folder that represents Dreamweaver, as this one specifically states CS5.5.
    I did modify the files in the Application directory to match the tutorial, and I even added .scss, .sass., .less files to the accepted file types in preferences but no matter what I seem to do I get no color coding....
    Do you know if it has anything to do with it being cs6, or some other variable option?
    Thank you, any help is appreciated.
    Sep 20, 2012 1:55 PM   in reply to Kricir
    Same issue here - no code hinting. Have gone over everthing 3 times
    Admin mode:
    MMDocumentTypes.xml, Extension.txt, User Extensions.txt
    Intalled successfully adamcoulombe / dw-compass-codehints
    According to DW is shows up properly however no change.
    Any help w/ this? Is it a CS6 problem? Other?
    Sep 20, 2012 8:24 PM   in reply to Moonshot0087
    Moonshot0087,
    I know on my end I stumbled across the solution and I do hope this works for you as well.
    If you are working in Mountain Lion with cs6 I can tell you I couldn't find one of the sets of files because they were in a HIDDEN /library folder in my user directory.
    If this is the problem that you are having, make sure first to go to terminal and turn on hidden files (copy this into terminal):
    defaults write com.apple.finder AppleShowAllFiles -bool true
    Then hold "Alt/Option" and right click "Finder" then click "Relaunch" in the pop up menu.
    From there you will be able to find the /Users/"USERNAME"/Library/Application Support/Adobe/Dreamweaver CS6/en_US/Configuration/extensions.txt and /Users/"USERNAME"/Library/Application Support/Adobe/Dreamweaver CS6/en_US/Configuration/DocumentTypes/MMDocumentTypes.xml.
    Once you edit those files restart Dreamweaver and everything should work just as expected.
    May 1, 2013 3:47 AM   in reply to Typo83
    I have added some extensions for dreamweaver and its working fine for me and I found it at http://webdesignsolutions.co.in/sass-extension-to-dreamweaver
    I hope this will work for all. Try it once.
    Jun 11, 2013 10:31 PM   in reply to Typo83
    I've not been able to find a solution to this anywhere.
    I'm using CS6 (creative cloud) on a win7 PC.
    I've followed through all of the steps that are posted in a couple of the solutions above - editing MMDocumentTypes.xml and both of the Extensions.txt files. I've noticed that all of the suggested solutions refer to earlier versions of DW, not CS6.
    LESS and SCSS files both open in DW following this, but I don't get any nice code colouring or hinting. Any help would be appreciated.
    Jun 11, 2013 10:36 PM   in reply to modelcitizencollective
