Would Gold Support be able to assist with an issue I'm having with our APNS Development Certificate? If not, besides the iOS forums where I've already posted, is there a good place to look for potential assistance? (The problem is I don't see a key associated with the certificate in Keychain Access so I can't generate the .p12 for my final step in the Viewer Builder).
You're using Apple's tools to create the certificate, so you might want to try the Apple developer forums. But first, I would try a couple things. Close and reopen the Keychain Access utility (you might even want to restart your computer). Then use the import command in the Keychain Access utility to import the .cer file you downloaded from the iOS Provisioning Portal. If the key stil doesn't appear under the certificate, revoke and delete the push certificates and try again.
