I just can't seem to get this video to encode correctly. Any Ideas??
Aug 3, 2012 12:32 PM
Tags: #video #h.264 #encoding #cs6 #ame #media_encoder
Attempting to encode the following video via AME CS6 and am currently running into the following problems:
-- When encoding at 30fps (H.264/mp4) -- the duration of the file is correct, but the audio/video runs super fast and sticks on the last frame of the video for the remaining time left.
-- When encoding at 15fps (3gp)-- the duration of the file and the audio/video are correct, but is very low quality.
-- When encoding at anything in between (H.264/mp4), the video stutters all the way through.
Very confused as to what is going on. I am simply looking to encode/compress the video in a high quality mp4 file. Any help would be greatly appreciated.
Format                                   : AVI
Format/Info                              : Audio Video Interleave
Format profile                           : OpenDML
File size                                : 30.1 GiB
Duration                                 : 57mn 14s
Overall bit rate                         : 75.2 Mbps
Video
Format                                   : RGB
Codec ID                                 : 0x00000000
Codec ID/Info                            : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
Duration                                 : 57mn 13s
Bit rate                                 : 73.8 Mbps
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 30.000 fps
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 8.005
Stream size                              : 29.5 GiB (98%)
Audio
Format                                   : PCM
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : 1
Duration                                 : 57mn 14s
Bit rate mode                            : Constant
Bit rate                                 : 1 411.2 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 44.1 KHz
Bit depth                                : 16 bits
Stream size                              : 578 MiB (2%)
Interleave, duration                     : 502 ms (15.06 video frames)
Interleave, preload duration             : 502 ms
    Aug 3, 2012 2:22 PM   in reply to romeogq
    What playback software is being used?
    Aug 4, 2012 7:32 PM   in reply to romeogq
    Next question.
    Does the original play without error?
    Aug 6, 2012 9:10 AM   in reply to romeogq
    OK, try this.
    Create a new Uncompressed AVI file from the original.  Does that new Uncompressed play OK?
    Aug 7, 2012 2:58 PM   in reply to romeogq
    Use the Microsoft AVI option and set the codec to None.  (Don't use "Uncompressed AVI", as that is for use when you have AJA hardware installed.)
    Aug 8, 2012 12:42 PM   in reply to romeogq
    It seems you don't have PPro or AE installed so AME isn't licenced to encode to AVI.
    Can you share your source?
    Aug 8, 2012 3:51 PM   in reply to romeogq
    Just pick any Preset and then open it to customize it.  There you can switch to Microsoft AVI
    Aug 9, 2012 6:58 PM   in reply to romeogq
    Then Dima's suggestion is most likely correct.  You will need to install PP or After Effects for this one.
