Show full slice name in property window?
Aug 8, 2012 7:22 AM
Normally when I select a slice, the property window shows the full slice name including page name. However for some unknown reason, it has now changed to showing only the _r?_c? suffix only.
Is there a way to revert it back so full name is displayed?
Bob
    Aug 8, 2012 9:12 AM   in reply to bobfei
    Try File > HTML Setup, select the Document Specific tab, and choose "doc.name" from the first dropdown menu.
    Aug 8, 2012 10:54 AM   in reply to bobfei
    Hmm... Do the slices have names in the Web Layer (in the Layers panel), or is each one simply labeled "Slice"? (The generic "Slice" would be typical here; handwritten names will override the automatic naming used by the Properties Inspector.)
    Aug 8, 2012 11:19 AM   in reply to bobfei
    Also, try this: Open a new document and create a slice. Does the same behavior occur?
