Premiere CS6 Hates My ProRes Files
Aug 8, 2012 1:20 PM
Tags: #premiere #final_cut #prores
I'm editing a project with footage that was shot on a couple Canon T2i's. 1080p and 720p, 23.976fps and 59.94fps. I converted the H.264s to ProRes422 using Episode Pro (v6.3) and then from there added Reel Names to the clips using qtchange.
I wanted to edit with ProRes because I know down the line I'll be adding a lot of effects and color correction. I'm working on a 2010 iMac (i7, 2.3gHz, 8GB RAM, no nVidia card, OS 10.6.8) and I'll run into a processor bottleneck with the raw H.264s. In an effort to save time and sanity down the line, I chose to go ProRes with my workflow. I could just as easily edit this in FCP but I'm trying really hard to not go back to it and I wanted Dynamic Linking as well, again because it will be effects heavy.
After watching a few clips, I realized I was getting some bad drop frames on one or two occassions. I can't drag the clips into the timeline directly from the Project panel. I can't drag from the Source panel either.
A lot of times, I'll have a clip selected in the Project panel and I'll hit F10 or F9, the keys I've mapped Insert and Overwrite to. Nothing. Doesn't work. Every once in a while the whole app will freeze up. Keyboard shortcuts are rendered useless. No playback.
But, if I use an H.264, it's fine on all counts. Drag and drop, no drop frames, keyboard shortcuts. So I'm wondering if I should ditch the ProRes (once and for all) and stay with the native files. Will my iMac handle it? Will I hate myself later when I get into finishing?
Thanks for all the help in advance, guys (I know this is beating a dead horse by now).
    Aug 8, 2012 1:28 PM   in reply to bdelillo
    Hmm I use ProRes daily and have no problems.
    Although honestly I would try to just edit native files first and then if it seems like you are having issues then use something else. I always try to avoid changing things unless something isn't working.  So my answer would be to just use Native files.
    Aug 8, 2012 1:51 PM   in reply to bdelillo
    If you have a moment to test - try using Adobe Media Encoder or Magic Bullet Grinder to make your ProRes files.  I have used both of these and had no issues with my ProRes files in Premiere.  That will take FCP out of the equation as a potential issue.
    Aug 8, 2012 2:03 PM   in reply to bdelillo
    You could try using DNxHD. Although needles suggestion might work too.
    But honestly I'd recommend at least attempting to just use H.264 so you can avoid
    transcoding until you run into the time where it starts causing a problem. That's
    what I would do.
    Aug 8, 2012 2:20 PM   in reply to bdelillo
    I didn't see anywhere - are you on CS6 or earlier?  I used to transcode over to ProRes when I was on 5.5 since H.264 playback from my 5D was sluggish and horrible.  CS6 has been a much different experience, and i just use the H.264 out of the camera now even when doing effects and Colorista, etc.
    Aug 8, 2012 2:34 PM   in reply to bdelillo
    bdelillo wrote:
    It's in the heading of the discussion thread.
    Shows how much attention I pay to what I read...
    I agree - it would be wonderful to stress about creatively cutting footage in Premiere and not tech issues.  That's the story of this software.
    Aug 14, 2012 8:59 PM   in reply to needles27
