apm567
File closes after trying to re-link images
Aug 8, 2012 2:15 PM
Tags: #cs5 #re-linking
I have been working with some illustrator files for a while and all of a sudden I cannot open them anymore. I do not even get an error message. I tried opening them on another computer. They open, but then when I order to re-link the images, the file just shuts down.
The files are quite large, but even when I make them smaller (smaller then when they were before this problem started), I still cannot open them.
I thought it might be related to the images, but also older files with no new images have the same problem.
Does anyone know what the problem might be?
    Aug 8, 2012 2:21 PM   in reply to apm567
    How are you transferring files between systems?
    Aug 8, 2012 2:30 PM   in reply to apm567
    Is the external hard drive in good order?
    It's possible corruption is being introduced somewhere when copying files. This is especially true if the files are all fine on the original system with the same version of Illustrator.
    Aug 8, 2012 3:13 PM   in reply to apm567
    If the files are bad on the original system, why would you assume they would be good when copied to an external hard drive and opened on another system?
    Bad files are bad files. They don't get "healed' by moving them.
    You may have internal hard drive issues if files aren't working on the system which created them.
    First thing to do is to disable any and all thrid party plugs in for Illustrator. Then relaunch and try again. If the problem persists, try removing the Illustrator preference files and try again.
    After that, try a new user on the same computer.
    After that, you'll need to describe your operating system mroe here for further tips
