Discount Code for Single Product
Aug 6, 2012 4:37 PM
Is it possible to create a discount code for just a single product? I know I can do it for a single catalog - but hoping I can do it on single products, too.
  • Liam Dilley
    Feb 28, 2012
    Aug 6, 2012 5:58 PM   in reply to threetwelve
    Hey there,
    Not at the moment no. You would have to have a unique catalog and place that product into it to be able to offer a discount for logged in users on that product or discount code.
  • mario_gudelj
    Oct 13, 2010
    Aug 8, 2012 4:53 PM   in reply to threetwelve
    There's no way to display products from different catalogues on the same page, at this stage.
    -mario
  • Liam Dilley
    Feb 28, 2012
    Aug 8, 2012 5:19 PM   in reply to mario_gudelj
    Not out of the box in a true sense, but you can.
    You kind of do though Mario if you have everything in the parent catalog and then have them also in the subcatalog. All will show under "Shop" if added into it for example.
    IT not the mix and match as above but if added to the parent they will show up.
    Aug 11, 2012 1:26 PM   in reply to threetwelve
    I've had to display two BC catalogs on one page whenever clients request this, which seems to be a common request. Often clients want one page displaying two different catalogs side by side.
    You can accomplish this with jQuery.
    Set up an empty div on the page that will hold the catalogs...
    <div id="the-catalog-1"></div>
    <div id="the-catalog-2"></div>
    Then include a script so jQuery will use Ajax to load in the normal BC catalog page from the BC server and insert it into the div on your page...
    <script type="text/javascript">
    $('#the-catalog-1').load('/promotional-items div.shop-main').slideDown();
    $('#the-catalog-2').load('/promotional-items/t-shirts div.shop-main').slideDown();
    </script>
    In this example I'm pulling a parent catalog named /promotional-items and reading only the content from that BC page that is within its div having class="shop-main"
    jQuery will let you load only part of the content from the BC catalog page, in this case, I only wish to load the catalogs and/or products displayed within the div class="shop-main" in order to avoid loading the entire catalog page which of course would include the page template which I don't want.  I only want the part of the page in which BC is using the BC catalog layout or small product layout to list catalogs/products, eliminating the normal page template it displays within. For docs see "Loading Page Fragments" on the jQuery documentation page for the load command here: http://api.jquery.com/load/
    In #the-catalog-2 in the example I am loading the products displayed within the t-shirts subcatalog off the promotional-items catalog.
    You would likely need to set some CSS to set the width and perhaps height of #the-catalog-1 etc. although in my example I have no height so nothing is displayed until the catalog page loads and then I'm using a jQuery slideDown() to slide the div open and down with the content in it.
    Of course in order to run jQuery code you site needs to load jQuery in your page template etc. If you don't know how to do that there are instructions on my site:
    http://www.atlantawebdesignga.com/_blog/Adobe_Business_Catalyst_Develo per/post/Loading_jQuery_-_Loading_Latest_jQuery_-_Test_If_jQuery_Loade d/
  • Liam Dilley
    Feb 28, 2012
    Aug 21, 2012 1:38 PM   in reply to AtlantaWebDesignGA.com
    That means it is not managble by clients on love sites though. They are stuck with that and can only request the developer to increas, change or adapt that implementation.
    At very least with that concept you would use, say a dynamic menu or catalalog list dump to pick up the URL and form the output. Menu likely hidden a dn only used so the client can control. A nice web app integrated as well can allow more functionality and client managble.
    Nov 29, 2012 10:23 AM   in reply to threetwelve
    I know this thread is several months old, but I need to do the same thing for my client - apply a discount code to just one product.  I think a solution may be to add the product to a second, disabled, catalog as well as the original catalog.  Then apply the discount code to the disabled catalog only.
    I may be misunderstanding something, but when I tried this, it appears to apply the discount (20% in my case) only to that one item in my cart.  Does anyone see a problem with doing it this way?  Thanks.
