Does Added Text Resolution Match Photo Resolution
Aug 8, 2012 7:27 PM
I am adding text to some screen grabs from an old 8mm movie.  The movie resolution is not very high.  When I add text to the screen shots, they are very low resolution.
I am assuming that the text resolution is simply matching that of the screen grab.  Is there anyway to set the text resolution different from that of the photo from the screen capture?
    Aug 8, 2012 8:32 PM   in reply to Bob Ward
    Are you adding text with the type tool or some text from another source?
    Aug 9, 2012 2:22 PM   in reply to Bob Ward
    There's no way to have different resolutions for the text and the background image.  If the 8mm frame grabs are so small that you have to use 4pt. type, then you'll see the small type pixellated when the image is viewed at a large size.  When you save the image as a flattened file (e.g., JPG), the resolution of all layers will be the same.
    What are you trying to do?  There may be workarounds.
    Ken
    Aug 9, 2012 2:54 PM   in reply to Bob Ward
    I guess one way around that might be to save the file as a photoshop pdf after adding the text.
    But the text will only be non pixelated if your viewing the file in a pdf reader such as adobe reader.
    If you open the file into an image editor the type would be rasterized and pixelated again.
    Aug 9, 2012 3:14 PM   in reply to Bob Ward
    Or maybe use Image>Resize>Image Size with resample checked and change the resolution to 300 (in the resolution box)
    Then add your text and the type will be less pixelated, but the image itself may be of bad quality.
    Aug 9, 2012 6:19 PM   in reply to Bob Ward
    You could put the text below the picture by making a new document at 300 resolution and then copy and paste your screenshot into that document.
    Add the text, then crop the document.
    On the original you can always make the text bigger than the default 72 size, if you just want larger text.
    Aug 9, 2012 8:19 PM   in reply to Bob Ward
    Yeah i don't know if my suggestion would really work.
    Maybe you could post a screenshot showing the picture at the vieing size and someone might have an idea.
    Aug 9, 2012 11:22 PM   in reply to Bob Ward
    Doesn't your video editing software allow you to create a text overlay?
    Alternatively, in PSE, first use Image...Resize and resize the pixel dimensions of the frame up to the pixel dimensions at which it will be viewed.  Make sure "Resample" is checked.  Then add your text as usual.
    Ken
