Can I change color of all objects at ones ?
Aug 9, 2012 1:53 AM
Tags: #color #change
Hello guys
I understand that's very fundamental question, and I promise I search the forum prior to posting, but perhaps it's my bad english and wrong phrasing, that leads to poor results. So if that has been discuss, please kindly don't waste your time, just link me to the post and I will read away.
I have very complex file, with hundreds of paths, shapes, text, outlined text,  etc... It's a brochure with graphs, scematich drawings and text.
Last moment, the client like the reverse the colors from (current) Black on white, to all White on dark gray background.
Problem is, I can't seem to find easy way to just change the colors, without selecting one by one, every single object. When I selest all and choose white, it start filling paths with solid fill... Editing it wastes allot of my time and I have many pages to do.
Is there any way to simple change color of everything at once, just from black to white ? Or do I have to go object by object manually ?
Thank you very much, for all the help so far, and I'm sincerly sorry to waste your time if that has been covered previously.
Good day
ciao ciao
Monika
    Aug 9, 2012 2:03 AM   in reply to mona oga
    This may work, depending upon the art.....
    Select all
    Choose Edit > Edit Colors > Invert Colors
    Aug 9, 2012 2:07 AM   in reply to mona oga
    Have you tried using these commands : Same Fill Color, Same Stroke Color?
    Aug 9, 2012 2:56 AM   in reply to mona oga
    When you want to edit all color at once and don't bother about where it is used, select all and Edit > Edit color > Recolor art.
    Aug 9, 2012 4:59 AM   in reply to mona oga
    In the future, get in the habit of always defining Swatches for colors you use in the design and always define them as Global Swatches. When you edit a Global Swatch, all objects to which that Swatch has been applied update accordingly.
    JET
