Headers and Footers
May 30, 2012 9:39 PM
It has become impossible for me to insert headers and footers (mainly for numbering).
I am getting a 'not responding' message every time I use the feature. I am working on 8MB to 15MB files.
I use Acrobat X Pro and my OS is Windows 7 Ultimate 64-bit
Paul
    May 31, 2012 6:32 AM   in reply to Paul Gauci
    Hi Paul,
    Try refrying the PDF by printing the PDF to Adobe PDF printer and create another copy of it. I am assuming that this PDF is from a third party PDF producer. You can check this from File Menu-> Document Properties -> PDF Producer and Manufacturer.
    Feel free to let us know the results.
    ~Sandeep V.
    Jun 1, 2012 5:45 PM   in reply to Paul Gauci
    Would you be willing to share any sample file with us? Can't really comment what's happening with it. Do you have 10.1.3?
    Jun 2, 2012 11:00 AM   in reply to Paul Gauci
    Use the 'Advanced Editor' and attach it here. Click on Reply and you should get this option on right top corner. You can use Dropbox etc. if you prefer.
    Aug 9, 2012 2:52 AM   in reply to Paul Gauci
    I don't know if Sandeep has downloaded the file, but your Dropbox link has now expired so nobody else can run tests.
    Please note that while some Adobe engineers visit these forums there is no official monitoring of threads, so no guarantee that a particular question will be responded to.
    Aug 9, 2012 4:15 AM   in reply to Paul Gauci
    It certainly shouldn't take that long to apply a HF layer.
    If you want to send me the file I can take a look and try to replicate the issue - private-message the download link if you wish to keep it off the public forums.
    Aug 9, 2012 6:54 AM   in reply to Paul Gauci
    Hmm..
    It's a fiendishly complex file (hundreds of image fragments and thousands of paths) so Acrobat is struggling a bit to rebuild the object tree. The HF thread within Acrobat's code is not particularly high priority so while it's thinking about stuff you're certainly not hardware-limited.
    I've added, updated and removed a set of HFs using Helvetica on our Windows 7 testbed (core i7 @ 2.67GHz) and the progress bar took about 10-20 seconds, but on a couple of runs it did struggle to complete (unsure why yet, it's not a leak). Don't use Arial as the font, the ArialMT typeface is monstrous and Acrobat has to subset it (you'll see the progress bar die around 90%). Helvetica is a lot faster.
    Aug 9, 2012 8:21 AM   in reply to Paul Gauci
    Generally I'd stick to type 1 and small Truetype files rather than the Unicode monsters that come with Windows - look at your fonts folder in 'details' view and you'll see how horrendous ArialMT Unicode is compared to the rest.
Bookmarked By (1)
