gama 19
PHOTOMERGE- PHOTOSHOP
Aug 9, 2012 5:46 AM
Hi, I´ve got a macbook pro,Software  Mac OS X Lion 10.7.4 (11E53)! I have tried to install adobe photoshop cs5 and cs6 trial, althought both of them doesn´t allow to make photomerge with the pictures catch of the computer screen (it doesn´t mather if it is in PNG or JPEG). Althouhg this feature works perfectly if I attempt with other pictures (not catch with this computer).
This versions of photoshop works perfectly in a  waio pc of mine.
Besides, I´ve tried in a mac with the previous software of a friend of mine, and there´s no incompatibility with Photomerge and screenshots.
I have also take my mac to see if there was a hardware problem, but is in perfect condition. So  I would like to ask if any incompatibility has been detected at this level, and what do you suggest me to do, since I need to buy this product for my work.
  • Noel Carboni
    Dec 23, 2006
    Aug 9, 2012 6:43 AM   in reply to gama 19
    Photomerge expects some overlap between adjacent exposures.  Assuming by your comments that you're capturing what's on each of your screens separately then hoping to put it together into a single image, there is no overlap.
    Is that indeed what you're trying to do?  Capture your desktop as it crosses multiple monitors and create a single unified image of the entire desktop?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 9, 2012 5:07 PM   in reply to gama 19
    Is there a way you could post two images that don't stitch, which you think should?
    Maybe it's just the Photomerge process itself that's failing for some reason on the new system.
    -Noel
    Aug 10, 2012 10:17 AM   in reply to gama 19
    Hi Teressa,
    I just ran Photomerge on png captures of Bing Maps under 10.7.4 with no problem. If you can post the images causing you  problems, I can try them as well.
    Are you getting any messsages, or does the resulting file just have separate layers with no blending?
    regards,
    steve
    Aug 10, 2012 11:58 AM   in reply to gama 19
    Hi Teressa,
    Those images merge fine on my machine. So the Untitled_Panorama file is not present, but Ps is still running? Or does the file just display the checkerboard?
    Have you tried this with the GPU enabled drawing deselected (Preferences> Performance)? I'm using a desktop Mac Pro so there's a difference in the video cards between our machines.
    regards,
    steve
    Aug 30, 2012 1:18 AM   in reply to SG...
    Hi Teressa, Steve, et al,
    Teressa - did you ever get this issue resolved?
    The reason that I ask is that I'm experiencing the same, frustrating issue.  I've created dozens of panoramic images on my Mac Pro in the US, but I'm now on an assignment in New Zealand for a year and brought a new MacBook Pro w/ Retina Display and the same issues are happening for me.  No matter what I've tried - starting with LR, exporting various files from LR and then opening in PS5, etc., the result is always the same - Photomerge chugs along and appears to be creating the "Untitled_Panorama" and then it briefly appears on the screen and is gone.  My original files are present and PS5 is running, but there's no panorama anywhere?
    Help me  Obi Wan Kanobi, you're my only hope!
    Tim!
    Sep 3, 2012 5:58 PM   in reply to Tim!
    I fixed it!!!
    I found the "fix" in an old post - finally.
    Go into your preferences panel, select "Units & Rulers," and if you have ruler units set to %, try something different - I reset mine to centimeters.  Restart photoshop.
    I hope that this works for whoever else is searching for a fix!
    Tim!
  • Noel Carboni
    Dec 23, 2006
    Sep 3, 2012 6:01 PM   in reply to Tim!
    That's interesting.  You've seen Photomerge fail with % but not with another setting?  FYI, I always set mine to pixels and I've had very good luck with Photomerge.
    -Noel
    Sep 3, 2012 8:55 PM   in reply to Noel Carboni
    Hi Noel,
    I just purchased this MacBook Pro about a month ago and made a fresh install of PhotoShop CS5.5 on it.  I've used Photomerge hundreds of times on my Mac Pro and don't recall any problems with it there.  I'm guessing that the default rulers setting must be percent.  I couldn't get Photomerge to work 'til today when I changed the ruler setting to centimeters.  I don't know what the issue is, but I'm glad that's resolved.  I've already generated three new panoramas, and fourth one is brewing right now...
    ~~TIm!
