Miiagod
Problems in placing .jpg images - size shrinks
Aug 8, 2012 9:24 AM
Tags: #problem #cs5.5 #images #placing
I have been working with InDesign for years and this is the first time I encouterred the following problem. Currently I am creating an online document with InDesign CS5.5.
The problem is that when I place (ctrl + D) an image (.jpg), some of them seem to "shrink" from their original size and become totally pixelated.
My original image is 192 x 380 px and it was placed as 46.08 x 91.2 px
I don't understand what might be the problem. For some of my images it seems to do this and for some not. There are some images that I have previously placed succesfully and then these same images are now shrinked when I place them. Could this be a setting change? I have tried everything, but nothing seems to work.
Very puzzled.
Any suggentions?
Miiagod
  • Rob Day
    Oct 16, 2007
    Aug 8, 2012 10:01 AM   in reply to Miiagod
    Resize your image resolution to 72ppi. By default ID places images at 100% of the output print size, not the pixel dimensions.
    See this:
    http://forums.adobe.com/message/4596195#4596195
    and this if you plan to upgrade to CS6:
    http://forums.adobe.com/message/4502849#4502849
    Aug 8, 2012 2:51 PM   in reply to Miiagod
    indesign don't pixelate images if you set them at 100% or less of the original sizes
    1st: export to pdfx1a to see if the screen resolution is the problem.
    2nd: select with white arrow and see if 100% is the numbre in the measures bar
  • Rob Day
    Oct 16, 2007
    Aug 8, 2012 3:42 PM   in reply to Fede Gianni
    A 192 x 380 pixel  image scaled at 100% that also measures 192 x 380 pixels on the ID page has to have an actual resolution of 72ppi:
    If the actual ppi is different (100 ppi below) and the scale is 100% then the ID object pixel width and height has to change:
    Aug 8, 2012 4:21 PM   in reply to Rob Day
    yes, my only point here is that you have to see the same pixelation in Id or Ps, pixelation should not be a prob if you have your jpg at 100%. Id only show what you have.
  • Rob Day
    Oct 16, 2007
    Aug 8, 2012 5:30 PM   in reply to Fede Gianni
    There are 2 problems pixelation and the image dimensions on the page. Placing at 100% solves pixelation but not necessarily the dimension problem—you need 72ppi actual res to solve both.
  • Rob Day
    Oct 16, 2007
    Aug 9, 2012 5:00 AM   in reply to Miiagod
    This means then that I have to change the resolution of all my images to 72dpi (a lot of work really for something that has worked earlier). What I don't understand is that why has this never been a problem before?
    I don't see any difference in behaviour, just checked CS3 and it works the same.
    I have done these kinds of documents with this same package over 200 pages
    Are you designing for web display? This would only matter if you are trying to view actual pixels at 100% where your ruler units need to be pixels.
  • Rob Day
    Oct 16, 2007
    Aug 9, 2012 6:39 AM   in reply to Miiagod
    As I mentioned in the previous post, this "resizing" has not happened before, even though I have placed images with higher resolutions than 72dpi.
    The scale percentage that shows in the Transform panel is the scale relative to print output so if you change image resolution the image dimensions have to change.
    ID does not resample when you scale—it's the same as resizing in Photoshop. If you change the resolution of an image with resample unchecked its dimensions have to change. So, a 5"x7" image at 72ppi becomes 1.2"x1.68" at 300ppi when you resize.
  • Rob Day
    Oct 16, 2007
    Aug 9, 2012 7:10 AM   in reply to Miiagod
    There is no print or image default. The output image resolution is relative to the scale of each image and shows as the Effective ppi in the Info panel when you select the image. The print resolution is chosen in the Print dialog and depends on the device
  • Rob Day
    Oct 16, 2007
    Aug 9, 2012 6:58 AM   in reply to Miiagod
    If your page dimensions are 800 x 600 pixels and you export the page as a JPEG, you would have to choose 72ppi if you want the exported JPEG pixel dimensions to also be 800 x 600.
    In order to keep specific pixel dimensions without resampling the pixels on export to an image format, the incoming and outgoing res has to be 72ppi
