Hi, I´ve got a macbook pro,Software Mac OS X Lion 10.7.4 (11E53)! I have tried to install adobe photoshop cs5 and cs6 trial, althought both of them doesn´t allow to make photomerge with the pictures catch of the computer screen (it doesn´t mather if it is in PNG or JPEG). Althouhg this feature works perfectly if I attempt with other pictures (not catch with this computer).
This versions of photoshop works perfectly in a waio pc of mine.
Besides, I´ve tried in a mac with the previous software of a friend of mine, and there´s no incompatibility with Photomerge and screenshots.
I have also take my mac to see if there was a hardware problem, but is in perfect condition. So I would like to ask if any incompatibility has been detected at this level, and what do you suggest me to do, since I need to buy this product for my work.
Photomerge expects some overlap between adjacent exposures. Assuming by your comments that you're capturing what's on each of your screens separately then hoping to put it together into a single image, there is no overlap.
Is that indeed what you're trying to do? Capture your desktop as it crosses multiple monitors and create a single unified image of the entire desktop?
-Noel
Hi Noel!
Thanks for your answer. I know what photomerge is about, and that it might have something in common in the images loaded, otherwise it won´t be able to join them. The images I used where screenshots from the bing maps (cmd+alt+4), but I´ve always been careful to make points in common. The problem is actually some kind of incompatibility between the screenshots catch with this mac and the photomerge. It can be caused by this new operating system, because the previous one does not have this problem.
Teresa
Message was edited by: gama 19
Hi Steve!
Thanks for your answer, I´m sending you the images that were screenshot in this mac.
The photomerge can read them in the begining, and when it is almost finished it even shows the final image resulting from the union of the parties. But then it just disappears without any briefing note and does not save it anywhere in the computer!
thanks for your concern!
Teresa
Hi Teressa,
Those images merge fine on my machine. So the Untitled_Panorama file is not present, but Ps is still running? Or does the file just display the checkerboard?
Have you tried this with the GPU enabled drawing deselected (Preferences> Performance)? I'm using a desktop Mac Pro so there's a difference in the video cards between our machines.
regards,
steve
Hi Teressa, Steve, et al,
Teressa - did you ever get this issue resolved?
The reason that I ask is that I'm experiencing the same, frustrating issue. I've created dozens of panoramic images on my Mac Pro in the US, but I'm now on an assignment in New Zealand for a year and brought a new MacBook Pro w/ Retina Display and the same issues are happening for me. No matter what I've tried - starting with LR, exporting various files from LR and then opening in PS5, etc., the result is always the same - Photomerge chugs along and appears to be creating the "Untitled_Panorama" and then it briefly appears on the screen and is gone. My original files are present and PS5 is running, but there's no panorama anywhere?
Help me Obi Wan Kanobi, you're my only hope! ![]()
Tim!
I fixed it!!!
I found the "fix" in an old post - finally.
Go into your preferences panel, select "Units & Rulers," and if you have ruler units set to %, try something different - I reset mine to centimeters. Restart photoshop.
I hope that this works for whoever else is searching for a fix!
Tim!
Hi Noel,
I just purchased this MacBook Pro about a month ago and made a fresh install of PhotoShop CS5.5 on it. I've used Photomerge hundreds of times on my Mac Pro and don't recall any problems with it there. I'm guessing that the default rulers setting must be percent. I couldn't get Photomerge to work 'til today when I changed the ruler setting to centimeters. I don't know what the issue is, but I'm glad that's resolved. I've already generated three new panoramas, and fourth one is brewing right now...
~~TIm!
Hi Tim!
That´s a precious information, thanks!
Well, I did not resolve all my problem actually,I just found a new program to help me with this! I start ussing " Snagit" which help me capturing the images I want (they are no more captured by the computer), and then the photomerge start working normally.
I think this only happens with the new macs, and with the new operating system, mine also has two months!
I'll try your tip!
thanks!
Teresa
