I have been working with InDesign for years and this is the first time I encouterred the following problem. Currently I am creating an online document with InDesign CS5.5.
The problem is that when I place (ctrl + D) an image (.jpg), some of them seem to "shrink" from their original size and become totally pixelated.
My original image is 192 x 380 px and it was placed as 46.08 x 91.2 px
I don't understand what might be the problem. For some of my images it seems to do this and for some not. There are some images that I have previously placed succesfully and then these same images are now shrinked when I place them. Could this be a setting change? I have tried everything, but nothing seems to work.
Very puzzled.
Any suggentions?
Miiagod
Resize your image resolution to 72ppi. By default ID places images at 100% of the output print size, not the pixel dimensions.
See this:
http://forums.adobe.com/message/4596195#4596195
and this if you plan to upgrade to CS6:
Thank you for your help on this. I opened the images in PS and indeed - some of the resolutions were 72dpi (placed fine), some 150dpi and some 300dpi (both resolutios placed smaller).
This means then that I have to change the resolution of all my images to 72dpi (a lot of work really for something that has worked earlier). What I don't understand is that why has this never been a problem before? I have done these kinds of documents with this same package over 200 pages and now this seems to be a problem. I have placed images with various resolutions with good results before. Is there a setting that I could tweak?
Many thanks.
I don't see any difference in behaviour, just checked CS3 and it works the same.
Are you designing for web display? This would only matter if you are trying to view actual pixels at 100% where your ruler units need to be pixels.
As I mentioned in the previous post, this "resizing" has not happened before, even though I have placed images with higher resolutions than 72dpi.
The scale percentage that shows in the Transform panel is the scale relative to print output so if you change image resolution the image dimensions have to change.
ID does not resample when you scale—it's the same as resizing in Photoshop. If you change the resolution of an image with resample unchecked its dimensions have to change. So, a 5"x7" image at 72ppi becomes 1.2"x1.68" at 300ppi when you resize.
If your page dimensions are 800 x 600 pixels and you export the page as a JPEG, you would have to choose 72ppi if you want the exported JPEG pixel dimensions to also be 800 x 600.
In order to keep specific pixel dimensions without resampling the pixels on export to an image format, the incoming and outgoing res has to be 72ppi
