When I import a pdf file made with InDesign into Quark some of the type disappears when printing. I can see it on the screen but it does not appear on the printed page. It will be in the middle of a paragraph just one line. Not a whole sentence or paragraph but one line at various points on the page.
The type that's dropping out seems to be a custom encoded subset of a Type 1 Futura font. Quark might not be able to read the custom encoding, though there is also some othe custom encoded text in the Ventures ad and somewhere else I wasn't able to spot.
Can I ask Why you are putting a full page PDF into Quark like this? The page seems to be complete on its own....
It's too time consuming to open every file and covert it when you don't know if the file will be a problem. We run a hundred files like this every week and never know if one will be a problem. We cannot open them in Illustrator since we often don't have all the fonts in our system that are in the file. On our own files we use eps but these are submitted files from customers and converting them all to eps is tedious and the files become very large. I have optimized files in the past but that has created other problems in the past.
If there is some setting I can have the customer change on his end I would be up to suggesting it to them.
The font is the same throughout that paragraph.
I stopped using Quark at version 6, but using it to impose PDFs like this used to be a recipe for disaster. That particular PDF is not flattened, and that may certainly be a factor. I'd take Rob's suggestion and convert it to X-1a and see if it helps, and ask your clients to send you PDF/X-1a in the future. I'd also suggest that if you do a lot of this, and it seems like you do, something like Quite Imposing, which is an acrobat plugin, would be a good investment.
I'm sorry Bob. you're right from here to China. Please forgiveme.
i only wanted to help solving a specific problem with a specific solution, because is very frustrating when something is not working.
there is a latin-american point of view of what assistance, or support are, that prays "we have to do it with the tools we have" (in spanish "lo atamos con alambre" = "tie it with wire" (?) approx) reasons are short budgets, or too much beaurocracy, that makes the optimal solution never cames o cames toooooo late, and needs of quick responses, sometimes the "wire" is the only solution. Unfortunately, after years of dealing with problems, this kind of thinking starts to take your entire brain.
http://www.quite.com/imposing/
The basic version is $475 US, so I find it hard to believe it wouldn't pay for itself in a couple of weeks.
