I've got some images in a fluid grid that work fine in the smaller sizes - they fit perfectly. But in the 'desktop' view, they are much too small and I'd like to just center them in the div.
I've read - or seen a tutorial - or heard in my sleep, I really don't remember where... but you're not supposed to mess with margains in the fluid grid page. Since I'd normally use auto to do that... is there an easy way to center the content in the column?
Yes, I'm new, but at least I try 100 ways first before I ask every question!! ![]()
If you post a link to your test page then you are likely to get quicker response here. People need to see your page structure to give you a suggestion.
Good luck.
Thanks but I don't have the page up as yet. If I were to include code sections - could I just copy/paste the relevant pieces from css and html?
And the align=middle.... I looked it up and don't see that tag available - and in any event, it didn't change things. Surprisingly, I even did the auto margains trick and though it showed on the tag inspector, overriding the other margain settings, it did nothing to change the alignment. I'm focusing too much on this right now and need to get back to overall development (and learning).
If anyone has any other suggestions, I'm certainly willing to try. I just don't see a lot on the fluid grid layouts in the tuts or here in the forums.
OK no problem. Can you post the code here (both HTML and CSS) so that we can create the page on our system and then give you the solution. To post the code use Advanced Editor
When you click the Advance Editor button, your screen will look liook like this:
Click on the arrows and you will be able to post the code here.
Good luck.
