a.n.bentz
Simple If-Then Statement
Aug 9, 2012 6:28 AM
Hello,
I'm working on a form and I have a question pertaining to three fields: V1, V3, and V4. I want V4 to be able to be the product of V1 and V3, if those values are filled. If not, I want to be able to manually put a number into V4.
I've researched and tried various different if,then statements, but none seem to be working. Please help!
Thank you so much,
Amanda
    Aug 9, 2012 6:44 AM   in reply to a.n.bentz
    How about using 2 fields, one calculated, and one for user entered value:
    var v1 = this.getField('V1').valueAsString
    var v2 = this.getField('V3').valueAsString
    if (v1 == '' && v2 =='') {
         this.getField('V4_UserEntry').display = display.visible
         this.getField('V4_Calculated').display = display.hidden
    } else {
         this.getField('V4_UserEntry').display = display.hidden
         this.getField('V4_Calculated').display = display.visible
    Aug 9, 2012 7:01 AM   in reply to MarkWalsh
    Another idea would be to use a single field, and calculate the value in the format script. Try something like this to see if it works:
         event.target.readOnly = false
    } else {
         var prod = // ... do your calculation here
         event.target.readOnly = true
         event.value = prod
    Aug 9, 2012 8:57 AM   in reply to a.n.bentz
    This should work in the Custom Calculation script:
         event.target.readonly = false
    } else {
         var prod = this.getField('V1').value * this.getField('V3').value
         event.target.readonly = true
         event.value = prod
    I was using the 'Format' script since it would retain the value the user has entered (the Calculate script will replace that value).
    Aug 9, 2012 9:42 AM   in reply to MarkWalsh
    This should work: Put the code in my previous message into the Custom Format script, and put the following into the Custom Calculation script:
    event.value = event.value
    Aug 9, 2012 11:13 AM   in reply to a.n.bentz
    Your initial message stated that you needed that to happen if Both fields were filled. If you only need to do the calculation if V3 is filled with a value, and allow entering a value in V4 oherwise, then change the IF line to:
    if (v2 =='') {
    Aug 9, 2012 12:02 PM   in reply to a.n.bentz
    To round the number to 2 digits, Change this:
    event.value =prod
    to this:
    event.value = Math.round(prod* 100)/100;
    Aug 9, 2012 3:28 PM   in reply to a.n.bentz
    You have 1 double quote, you need to type 2 single quotes. (or 2 double quotes)
    Aug 9, 2012 3:44 PM   in reply to a.n.bentz
    Also, 'event.target.readonly' should not be capitalized (That was my mistake in the first script, the 'O' should be lowercase)
    Aug 10, 2012 7:01 AM   in reply to MarkWalsh
    I would be careful using JavaScript's Math.round method since there are known issues with it working properly for all values.
    JavaScript Rounding Errors
    Round-off error
    Grade School Sample Files look at the Rounding test, it contains a document level funciton that does not suffer from the rounding error common in JavaScript.
