Photoshop errors
Aug 9, 2012 1:14 PM
Tags: #error #installation #photoshop_64_bit #photoshop_32_bit
I've been trying to install CS5.5 Design Standard on a couple XP machines (SP3). I've had no problems on a number of other similar machines using the batch scripts I wrote, but the suite refuses to install on 2 computers. I can get Acrobat on okay using the batch script, but the script for Photoshop, InDesign, and Illustrator fails. I then tried installing those 3 manually as I have done on other machines successfully, but for these 2 it will only install InDesign, Illustrator, and all the extras that come with them. Photoshop refuses to install.
There errors I get are as follows. It seems that it's trying to install as 64bit on a 32bit OS even though I don't even get a 64bit option when selecting the applications to install. I *do* get those options when installing on Win7 64bit, so this is baffling. Any thoughts? I can't seem to force this to install!
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 3 error(s), 5 warning(s)
WARNING: DW024: The payload: Adobe Photoshop CS5.1 Core  {08EF22BC-43B2-4B4E-BA12-52B18F418F38} requires a UI parent with following specification:
                Family: Photoshop
                ProductName: Adobe Photoshop CS5.1 Core_x64
                This parent relationship is not satisfied, because this payload is not present in this session.
ERROR: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has required dependency on:
                Family: InDesign
                ProductName: Adobe InDesign CS5.5 Icon Handler x64
                MinVersion: 0.0.0.0
                This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
                Removing this dependency from list. Product may function improperly.
WARNING: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has recommended dependency on:
                Family: Adobe Web Suite CS5.5
                ProductName: Adobe Media Encoder CS5.5 X64
                MinVersion: 0.0.0.0
                Removing this payload from the dependency list.
WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
WARNING: DW031: Payload:{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 has been updated and has been selected for repair. The patch {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 will be uninstalled now.
ERROR: DW020: Found payload conflicts and errors:
ERROR: DW020:  - Adobe InDesign CS5.5 Application Base Files depends on Adobe Linguistics CS5.5 to be installed.
FATAL: DW020: Conflicts were found in the selected payloads. Halting installation.
