cware97
downloads
Aug 9, 2012 12:18 PM
i seem to be having a bit of trouble. i can download adobe downloads but once it get to the screen saying "Sign in required" , click sign in, than it  says either your computer is offline or the clock on your computer is set incorrectly. it wont let me go any farther. does anybody have any suggestions????
  • JJMack
    Jan 9, 2006
    Aug 9, 2012 1:59 PM   in reply to cware97
    It sound like you downloaded an adobe dowloader then when you run it, it wants you to login to your Adobe account however it has some problem and thinks your computer is not connected to the internet.  It may be an Adobe air application and something has gone haywire in Adobe Air.  You may want to download the Adobe Air installer. Run it. If it fails try un-installing Adobe Air and try again to install Adobe Air.  If your running windows you may first want to download Microsoft FixIt and see if it list Adibe Air and select to Adobe Air to be fixed by FixIt.
  • Noel Carboni
    Dec 23, 2006
    Aug 9, 2012 5:27 PM   in reply to cware97
    I take it your clock is not set incorrectly?
    If you're running Windows, set your time via the Internet by right-clicking your clock in the Taskar, choosing Set Date/Time, click the Internet tab, click the [Change Settings] button, and then click the [Update Now] button.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 10, 2012 9:05 AM   in reply to cware97
    What OS are you running, specifically?
    Did you get the download from Adobe.com?  Even if you did, perhaps you should download it again.  I know it's huge,but it could have been corrupted.
    Do you have security software that may be blocking the installer from reaching Adobe.com to verify your Adobe ID?
    -Noel
  • JJMack
    Jan 9, 2006
    Aug 10, 2012 9:08 AM   in reply to cware97
    Did you look into Adobe Air I beleive the Adobe Downloader is an Adobe Air application and I have seen the Problem your having which I the was cause by an Air problem it could not login.
