christevenson
HTML/CSS code for line length on pages.
Aug 9, 2012 2:15 PM
Tags: #line #length
Quick question for anyone willing to help. I need to cut down on the line length on some of my pages, (on the report pages under the table of contents tab in the navigation). I'm pretty good with coding but for some reason I can't get this to work. Thank you everyone.
Site URL: litterdatas.com/businesscatalyst.com
    Aug 9, 2012 2:47 PM   in reply to christevenson
    Hello christevenson,
    Looks like your template is missing a div or two. If you wrap your page content in these div:
    <div class="wrap_fullwidth" id="main">
        <div class="center" id="grid">{tag_pagecontent}</div>
    </div>
    it will center your content and give it a width of 940, along with the white bg. Though you will have to change the color of your text then.
    If you don't want the white bg, do not use the id="main" surrounding div.
    This should fix the length of your lines.
    You may also want to use <p>, <h2> tags for paragraphs and headings instead of just using an unordered list for page content.
    Hope this helps,
    Chad Smith | http://bcgurus.com/Business-Catalyst-Templates for only $7
    Aug 9, 2012 4:12 PM   in reply to christevenson
    Have you published your changes or are you on a "working copy"; for the page and the template? Other than that, not sure why it wouldn't update on the live site.
    Hope this helps,
