Having Trouble Installing - Exit Code 7
Aug 9, 2012 2:57 PM
Hey guys,
I have installed parts of Design Premium CS5.5 a while back but recently have decided I want to add in Fireworks. When I run the installer I get this:
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 2 error(s), 5 warning(s)
WARNING: DW065: Display requirements not met for {60E59A6C-7399-495A-B85C-C829F4E59602}
WARNING: DW065: Display requirements not met for {8DADF070-FE60-4899-8EF0-4242E7702F7D}
WARNING: DW065: Display requirements not met for {1C9D6B02-8B92-4E40-8B22-37D8C95430F0}
WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW034: Warning: {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
ERROR: DW020: Found payload conflicts and errors:
ERROR: DW020:  - Adobe Flash CS5.5 depends on Adobe Flash Player 10 Plugin to be installed.
FATAL: DW020: Conflicts were found in the selected payloads. Halting installation.
    Aug 9, 2012 11:53 PM   in reply to wuaiwuai87
    Uninstall Flash Player 11, then try again
    Mylenium
    Aug 10, 2012 4:46 PM   in reply to wuaiwuai87
    Have you checked the link posted by  Mylenium and used the uninstaller to remove the flash player ?
    Aug 10, 2012 6:48 PM   in reply to wuaiwuai87
    No , Chrome has the in-built flash player.
    What happened when you tried installing the CS5.5 again ?
    can you post the latest install log to refer ..
