InDesign CS5.5 freezes when creating an idml file
Aug 9, 2012 9:19 AM
Good Day All,
I have been using inDesign since it started and have never come across this problem. I have a file that I intially created in CS4, converted to CS5 and now CS5.5. I have been trying to convert it to an IDML file and EVERYTIME it hangs and freezes. It actually produces a file but non-useable. I have been struggling with this for the last two days.
I have;
removed cache recovery files
looked at all styles to ensure optical kerning wasn't on (seems like a common problem)
rebuilt the file and renamed it
replaced Adobe Garamond Pro with Garamond Premier Pro
tried it on another machine
Re-installed CS5.5
I am using Windows 7 Ultimate with CS5.5 the document is about 11 pages long and packaged and zipped is 34.0Mb
I am starting to pull my hair out here!! Any help would be GREATLY appreciated.
Thanks!!
Curtis
    Aug 9, 2012 3:38 PM   in reply to kona72blast
    Try exporting half the pages at a time, then half of the half that fails, and so on until you get to the page that has a problem, then dlete half the objects at a time until you isolate what is causing the problem.
    Aug 9, 2012 3:59 PM   in reply to kona72blast
    Try saving each one separately as a new .ai file.
    Aug 9, 2012 4:25 PM   in reply to kona72blast
    It fails with NOTHING on the page?
    Aug 9, 2012 4:49 PM   in reply to kona72blast
    What made you think it was the .ai files? You need to isolate the objeect that is corrupt. It could easily be any of those things.
    Aug 9, 2012 5:24 PM   in reply to kona72blast
    It could be the frame, or the text itself.
    Jun 3, 2013 11:22 AM   in reply to Peter Spier
    Hey Peter.  I'm having a similar problem that I'm pretty sure is caused by a corrupt JPEG.  I can't even delete the JPEG.  InDesign crashes everytime after giving me an error (Error code: 3).  I can't export to IDML, though I have been able to save all my text (over 100 pages) by exporting to PDF without any images.  I've refreshed preferences, deleted recovery files, and everything else I can think of.  I've had this problem with some of the images before and simply deleted the corrupt file and placed a new PSD in place of the corrupt JPG, but, for some reason, I can't get passed this one image.  Everytime I scroll down to the page with the bad image, I begin to get error after error.  I can't select it to delete it.  Very frustrating.  Any help is greatly appreciated.
    Jun 3, 2013 11:52 AM   in reply to opendoorent
    No promises, but a couple of things you can try...
    Open as a copy. Sometimes this works.
    Delete or move the offending jpg from it's current location so it becomes a missing link. Rather than trying to select it on the page, select it in the links panel and relink. (you can even try this without making it missing).
    Jun 4, 2013 12:01 AM   in reply to Peter Spier
    Thanks for the reply, but it didn't work.  I tried to move the jpg but as soon as I get to that page or click on it in the links panel, I automatically get an error code: 3 message and then the software just cascades from there.  When I try to relink the graphic in the links panel nothing happens.  I even get an error when trying to unembed the graphic.  I've tried just about everything.  I'm think that if maybe I could just delete that entire page without actually looking at the page, I may be able to recover the rest of the document.  This has been one of the biggest headaches I've ever had to deal with as far as software goes and I deal with it every day (I'm a developer).  Any other suggestions are more than welcome.
    Oh, and I wasn't sure how to "open as a copy."  I made a copy of the file and tried to open it but it reacted the same as the original.  Perhaps I misunderstood your meaning?
    Thanks again for your help.
    Jun 4, 2013 3:41 AM   in reply to opendoorent
    I can't say I find that surprising. I think you have some serious file damage. Open as a copy is one of the radio button options in the File > Open... dialog.
    If you have a Windows machine available, you can try this: Adobe Community: Program for restoring corrupted InDesign documents (for Windows only) or you can send me a Private Message (click my name to go to my profile) and I can send you directions for sending the file to me and I'll try the tool for you, but it's also a long shot. Markzware has a file recovery service you should consider if the cost to rebuild will be more that $200: Bad InDesign or Quark File Recovery Submission Form
    Jun 4, 2013 3:43 AM   in reply to opendoorent
    Is this image embedded rather than linked? That would be very unfortunate.
