yep80
if statement
Aug 8, 2012 7:46 PM
I have an if statement based on the result of a calculation.  The if statement works if you enter a number manually but it won’t work as the result of a calculation. Can anyone let me know why?
I have copied the if statement below. Text 2 is the calculation field.
if (this.getField("Text2").value=="18") {
event.value = "Category 1"
      } else if (this.getField("Text2").value=="12") {
      } else if (this.getField("Text2").value=="11") {
      } else if (this.getField("Text2").value=="16") {
event.value = "Category 3"
      } else if (this.getField("Text2").value=="10") {
      } else if (this.getField("Text2").value=="17") {
event.value = "Category 2"
      } else { event.value = 0}
Cheers
    Aug 9, 2012 5:55 AM   in reply to yep80
    Try using this.getField("Text2").valueAsString instead of .value and see if that works properly
    Also, I would suggest using a 'Switch' command instead of the multiple if/else if commands.
    switch(this.getField("Text2").valueAsString) {
    case '18':
    case '12':
    case '11':
      break;
    case '16':
    case '10':
      break;
    case '17':
      break;
    default:
      event.value = 0
    Aug 9, 2012 4:02 PM   in reply to yep80
    I'm not understanding exactly what you are saying. What is the calculation you are using? How is the calculated field (I am assuming 'Text2' is your calculated field) formatted?
    Are you sure that the calculated values are EXACTLY 18, 12, etc.? If they are 18.01 and you are have the format set to 0 decimal places, then it won't work because you are comparing the actual value, not the formated value. Other than that, I'm not sure exactly what the issue you are having is.
