get xmp files from cr db
Jul 25, 2012 10:55 AM
Tags: #raw #xmp #sidecar #databse
Hi
I forgot to change my options for xmp sidecar files in bridge last time I installed it. For a good two months it's been saving xmp data in the camera raw databse instead of in sidecar XMP files.
Now I need to move a whole bunch of raw files to a new computer and I don't want to lose all the camera raw adjustments. Is there a trick to write out the info it has in the databse to XMP files along with the corresponding raw files?
thanks
  • Noel Carboni
    Dec 23, 2006
    Jul 25, 2012 11:16 AM   in reply to dutotone
    I suppose it's possible but I've never seen such a function.  It might be better to ask in the dedicated Camera Raw forum:
    http://forums.adobe.com/community/cameraraw
    -Noel
    Jul 25, 2012 12:43 PM   in reply to dutotone
    In Bridge, select a folder containing the raw files, then go to the Tools menu in Bridge:  Tools > Cache > Build and Export Cache.
    Jul 25, 2012 1:02 PM   in reply to dutotone
    The raw adjustment settings should have been exported too as part of the cache, but I can't personally vouch for that because I have never, ever set my preferences not to build XMPs and export them to folders whenever possible.  As the late Bruce Fraser used to put it, that would be "sheer insanity"—as you're now finding out.
    Jul 25, 2012 1:14 PM   in reply to station_two
    As I replied on the ACR forum:
    The camera-raw database is stored in (Windows 7):
    C:\users\yourusername\AppData\Roaming\Adobe\CameraRaw\Database
    And there is an “Export Settings to XMP” command on the ACR menu that appears to create XMP files for each raw file, but I haven’t tried it.  You might just Google that menu item to confirm what it does.
    Jul 25, 2012 1:35 PM   in reply to dutotone
    At the top of ACR’s righthand panel, where it says Basic in the title bar if you’re on the first toning tab, there is a little three-dots-three-lines icon with a tiny arrow in the corner on at the right end of where it says Basic.  If you click on that icon you’ll get a menu of quite a few things including resetting camera raw defaults and saving new ones, and what view you want to see in the main window.
    I don’t know about converting to DNGs – if it’s smart enough to know where the settings are for each particular image or if it just uses whatever the current setting is for where to look and won’t find settings for the images that don’t have them where its currently set to store the settings.
    Do you at least know exactly which images are the ones that have their settings stored in the ACR Database or are you guessing?  I’d hate to have you reset settings for images that aren’t in the database but do have XMP files.  You should probably test what happens in this case, to make sure you’re not overwriting your XMP settings with defaults.
  • Noel Carboni
    Dec 23, 2006
    Jul 25, 2012 3:15 PM   in reply to station_two
    As one who prefers the database, I find it amusing that others feel I'm "insane" or "crazy" (however right they may be) because of that choice.
    Adobe has provided the ability to maintain the settings in a database.  Personally, given their track record for file handling, I think anyone who would allow Adobe software to write back into the folders containing their original files is being irresponsible, but to each his own.
    I don't recall the default being to use the central database, though.   In fact, I remember having to switch it the other way.
    -Noel
    Jul 25, 2012 7:49 PM   in reply to ssprengel
    ssprengel wrote:
    …I’d hate to have you reset settings for images that aren’t in the database but do have XMP files…
    Is that scenario even possible?  I thought the info was kept in the central database regardless of whether you have XMPs in the folder(s) or not?
    I'm not disputing it at all, I'm just calling on your amply demonstrated superior knowledge of Camera Raw as evidenced in years of helping others at the Camera Raw forum the better to inform myself.
    Jul 25, 2012 7:57 PM   in reply to Noel Carboni
    Noel Carboni wrote:
    …I think anyone who would allow Adobe software to write back into the folders containing their original files is being irresponsible, but to each his own…
    Pending any forthcoming confirmation or correction by ssprengel to my understanding as far as the info being kept in the central database regardless of whether you have XMPs in the folder(s) or not, that would be a moot point, wouldn't it?  Just asking you.
  • Noel Carboni
    Dec 23, 2006
    Jul 25, 2012 8:05 PM   in reply to station_two
    Moot?  Not in the slightest.  I would be happy to hear that the central database is written regardless, but even if it were not I wouldn't want Adobe writing any files back to the folders containing my camera files.  They never seem to have gotten out of the 1990s with regard to file handling.  I've never heard of an application as likely to screw up file operations as Photoshop.
    Also, I'm apparently not as worried about retaining info from my past edits as many folks.  Generally speaking, I don't do all that much special to raw files in Camera Raw, and I could re-create the steps to developing a good image in a few heartbeats anyway.  I tend to concentrate on getting things right in the original capture, then the fancier things I do to photos (such as blurring backgrounds or cloning out zits) I do in Photoshop proper anyway.  I'm not saying this is better or worse than what others do, just the way I do it.  A complete loss of Camera Raw data wouldn't make me more than mildly concerned anyway.  That said, I don't tolerate loss of data and have it all backed up a number of different ways.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jul 26, 2012 7:09 AM   in reply to dutotone
    Thanks for the follow-up.
    dutotone wrote:
    they should really provide a proper clean up script
    I'm not sure it gets everything, but there is this:
    http://www.adobe.com/support/contact/cscleanertool.html
    -Noel
    Jul 26, 2012 1:27 PM   in reply to dutotone
    dutotone wrote:
    …Noel is absolutely correct, the default is to have sidecar xmp files…
    As well as the sensible setting to keep, in Bruce Fraser's and my opinion.
    It's very convenient to have the XMP travel along when you move or copy files.
    dutotone wrote:
    …Also, I dont think cr stores anything in the database unless you tell it to. If you delete a xmp file, the adjustments are gone.
    Well, that kind of answers my question, though it had never occurred to me to delete an XMP file by itself, that's why I keep them invisible in Bridge.  But perhaps, just maybe, the adjustment settings get deleted from the central database when you nuke the XMP file?
    Jul 28, 2012 9:54 AM   in reply to station_two
    My experience has been that storing side-car .xmp files in the same folder as my images bogs Bridge down enormously — particularly if you have many files in a folder.
    I was caught-out (and badly burned!) after installing new software by ACR's default Prefs. to store XMPs locally.
    There is no way to move sidecars back into the central ACR Database so  finally, in desperation, I simply trashed all of the sidecars and re-processed all of the affected .nefs.
    Jul 28, 2012 9:29 PM   in reply to CameraAnn
    CameraAnn wrote:
    My experience has been that storing side-car .xmp files in the same folder as my images bogs Bridge down enormously — particularly if you have many files in a folder…
    Does that hold true for you in any version of Bridge, or just the latest one in CS6?
    Essentially, my working versions of Photoshop and Bridge remain those in CS4, and I have a dedicated minimal system (4 GB Intel MacBook literally rescued from the trash) to run just ACR 7.1 hosted by Photoshop 13 ("CS6") and connected via Ethernet to my main working G5 Quad, with switchable, shared, dual, side-by-side external monitors for both systems.
    I do not experience any slowdowns in Bridge 3.0.0.464 and or 5.0.0.399, but then, I have the feeling that I have only a fraction of the number of files per folder you must keep—mostly under 200 or 300 image files per folder.
    Aug 9, 2012 8:46 PM   in reply to station_two
    I am so sorry not to have answered before this but have only just found your post.
    I am now using CS6 exclusively so my comments did mostly relate to Bridge CS6 — although I fitst became aware of the issue  with CS 5.5.
    I often do have very large folders with perhaps several thousand images in a single one — untill I get round to re-organising into some sub-folders!
    I definitely find it far more efficient to keep all my metadata in a central ACR Database and it is very quick and simple to export .xmp Suitcases to any designated folder if I am burning to a DVD for someone or uploading to an FTP web site.
    What I DO need is a way to"export" Sidecars back to the ACR Database if I have ever exported them to an Images folder.
    At the moment, it seems that I only have the option of deleting an .xmp and then I have to go back into ACR and re-do the conversion from scratch if I want to put the metadata back into the central Database.
    Aug 9, 2012 8:56 PM   in reply to CameraAnn
    Thanks for elaborating, Ann.
    Under the conditions you describe, I'd give serious consideration to working with DNGs, just to keep all the adjustments within the DNG wrapper, and forgetting about both the central db and xmp files.
    Good to hear from you, Ann.
