Getting java.lang.IllegalArgumentException: err.io.short_read exception when reading image data
Aug 2, 2012 10:01 AM
Tags: #flash #coldfusion
We use Flash to generate dynamic graphics and convert them to a PNG graphic by posting the base64 encoded bitmpa data to a coldfusion page, which saves the graphics file on the server.
This works well most of the time but for certain larger graphics we a ColdFusion exception in the post page, as follows:
08/02 12:40:16 error ROOT CAUSE:
        at coldfusion.filter.FormScope.parsePostData(FormScope.java:325)
        at coldfusion.filter.FormScope.fillForm(FormScope.java:295)
        at coldfusion.filter.FusionContext.SymTab_initForRequest(FusionContext.j ava:377)
etc....
I have not been able to find out whether this is a problem with the Flash code that does the posting or with some other configuration issue. The maxumum post size is 200MB and the images data is less than 200K
The Flash code for posting:
var img_source:BitmapData = new BitmapData (this.width, this.height+5);
img_source.draw(this);
//encode the bitmapdata object and keep the encoded ByteArray
var img_byte_array:ByteArray = PNGEncoder.encode(img_source);
var imgURLRequest:URLRequest = new URLRequest(image_url);
var requestVars:URLVariables = new URLVariables();
requestVars.upload_image_name = image_name;
// Convert to Base 64
requestVars.upload_image_data = Base64.encodeByteArray(img_byte_array);
imgURLRequest.data = requestVars;
imgURLRequest.method = URLRequestMethod.POST;
navigateToURL(imgURLRequest, "_self");
The ColdFusion page:
<cfsetting showdebugoutput="no">
<cfparam name="upload_image_name"                              default="">
<cfparam name="upload_image_data"                              default="">
<!--- Image was posted to the server, save it --->
    <html>
    <head>
    </head>
    <body>
      <cfoutput>Actual Size of image: #Len(upload_image_data)#</cfoutput><p>
    <!--- Save the image file --->
    <cffile action="write"
      file= "#Application.properties.flash_test_result_tmp_directory##upload_imag e_name#"
      output="#ToBinary(upload_image_data)#"/>
    <button type="button" onClick="this.close();">Close this window</button>
    </body>
    </html>
