No lighting effects
Aug 10, 2012 3:03 AM
Using cs6, Filter>Render>Lighting Effects is grayed out and non responsive. Every other filter seems to work fine,
    Aug 10, 2012 3:22 AM   in reply to CaptChuck
    Color Mode and bit depth of the active image are …?
    Aug 10, 2012 5:09 AM   in reply to CaptChuck
    What are your »Use Graphics Processor«-settings in the Performance Preferences?
    Aug 10, 2012 5:17 AM   in reply to CaptChuck
    If a Shape Layer is targeted, Lighting Effects will be unavailable because LE, like all Ps filters, operates on pixels. Other filters will be available but will prompt you to rasterise the SL. There is a UI inconsistency here.
    If the target is a SL (first make a hidden duplicate of the SL if you think it may need edited at some time), right-click it in Layers panel and pick Rasterize, then LE will be available.
