I have 2 PCs, both running Win7 Home Premium current with all patches as well as current versions of Chrome, IE9, and Firefox. My 64bit desktop runs Flash videos just fine with all 3 browsers. All was OK until the last day or two. Now my 32bit laptop runs Flash videos in Chrome, but will not run videos in IE9 or Firefox - they load the page where I should see that page that is white with the little puzzle icon in the middle that I can click on to start up the video, but all I get in IE & Firefox is a page that has normal stuff on the sides, but the video part of the screen stays blank black or blank white depending on whether IE or Firefox. I uninstalled both Shockwave and Flash layers, rebooted, and then downloaded/installed these two items from Adobe.com:
1 Adobe Flash Player 11.3.300.268
2 Adobe Shockwave Player 11.6.5.635
And then rebooted again.
Still no progress on getting the videos to play. What to do??
Added 8/9/2012
Still wont play videos in IE9 or Firefox. Here's a link to a video that will not play (it plays OK in Chrome). http://www.revolutiongolf.com/home/video/1775566388001
Chris - no ideas?
I'd recommend looking at the following FAQ. In particular, try the two test links in the tech note and try disabling hardware acceleration to see if that makes any difference.
How do I troubleshoot and report problems with Flash Player Video?
Chris,I'm no tech and following the sequence to pin this down is, I guess, beyond me. Check if you can see an HTML5 video See the following videos in an HTML5 supported browser.HTML5 video
Non-HTML5 videoIf you can see the HTML5 video properly, but can’t see the non-HTML5 video, there could be an issue with Flash Player. If you can’t see both the videos, it can be an issue with your device drive. I was able to play both the two videos above using IE9. The next video played OK with hdw acceleration either on or off. http://www.adobe.com/products/flashplayer.html I have attached the dxdiag.txt file to this email. Do I also need to send it to the bug report? Thx
[private data removed]
This is a public forum; please do not post your email address and other private data (by sending the entire notification message back to the forum).
OK - certainly did not intend for my email address or whatever to appear in the forum reply. Actually, I thought I was replying to a private email from Chris.
But - I did include an attachment of the dxdiag.txt with my reply. Did that attachment get to Chris or whoever needs it?
No, you need to post such data directly in the forum (your topic is http://forums.adobe.com/thread/1046717)
Unfortunately attachments are currently disabled in the forum; you need to post/paste the contents of the dxdiag.txt file inline.
P.S. you'll need to use the keyboard shortcut Ctrl+V to paste into the forum editor.
Of course you can also send an email reply with the dxdiag.txt data in the message body; that will be posted in the forum.
here is the dxdiag.txt
System Information
Time of this report: 8/9/2012, 21:36:07
Machine name: CATHY-PC
Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: T-6345u
BIOS: BIOS Version 89.28
Processor: Intel(R) Pentium(R) Dual CPU T3400 @ 2.16GHz (2 CPUs), ~2.2GHz
Memory: 2048MB RAM
Available OS Memory: 2038MB RAM
Page File: 1152MB used, 2924MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 965 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 965 Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A02&SUBSYS_0560107B&REV_03
Display Memory: 358 MB
Dedicated Memory: 0 MB
Shared Memory: 358 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SEC4442
Native Mode: 1280 x 800(p) (60.004Hz)
Output Type: Internal
Driver Name: igdumdx32.dll,igd10umd32.dll
Driver File Version: 8.14.0010.1930 (English)
Driver Version: 8.15.10.1930
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 19:14:54, 536576 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-6942-11CF-4174-6A25A2C2C535}
Vendor ID: 0x8086
Device ID: 0x2A02
SubSys ID: 0x0560107B
Revision ID: 0x0003
Driver Strong Name: oem7.inf:Intel.Mfg:i965GM0:8.15.10.1930:pci\ven_8086&dev_2a02
Rank Of Driver: 00EC2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeVC1_B
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_8384&DEV_76A0&SUBSYS_107B0567&REV_1002
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: n/a
Date and Size: 11/20/2010 05:00:21, 304128 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2834
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/24/2011 21:58:37, 258560 bytes
| Driver: usbd.sys, 3/24/2011 21:57:53, 5888 bytes
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/13/2009 18:11:24, 80896 bytes
| Driver: kbdclass.sys, 7/13/2009 20:20:36, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Synaptics PS/2 Port Compatible TouchPad
| Matching Device ID: *pnp0f13
| Upper Filters: SynTP
| Service: i8042prt
| Driver: SynTP.sys, 8/14/2009 09:54:54, 223792 bytes
| Driver: SynTPAPI.dll, 8/14/2009 09:53:58, 161064 bytes
| Driver: SynCOM.dll, 8/14/2009 09:53:54, 169256 bytes
| Driver: SynCtrl.dll, 8/14/2009 09:53:56, 206120 bytes
| Driver: SynTPRes.dll, 8/14/2009 09:54:04, 8095016 bytes
| Driver: SynTPCpl.dll, 8/14/2009 09:54:02, 1070376 bytes
| Driver: SynCntxt.rtf, 8/14/2009 09:43:48, 7793223 bytes
| Driver: SynZMetr.exe, 8/14/2009 09:53:52, 247080 bytes
| Driver: SynMood.exe, 8/14/2009 09:53:50, 238888 bytes
| Driver: SynTPEnh.exe, 8/14/2009 09:53:50, 1549608 bytes
| Driver: SynTPCOM.dll, 8/14/2009 09:54:00, 107816 bytes
| Driver: Tutorial.exe, 8/14/2009 09:53:54, 337192 bytes
| Driver: InstNT.exe, 8/14/2009 09:53:46, 124200 bytes
| Driver: SynISDLL.dll, 8/14/2009 09:53:58, 197928 bytes
| Driver: SynUnst.ini, 8/17/2009 21:15:46, 594369 bytes
| Driver: SynChiralRotate.mpg, 9/17/2008 00:13:08, 382277 bytes
| Driver: SynFlick.mpg, 9/2/2008 22:27:28, 737975 bytes
| Driver: SynPinch.mpg, 9/2/2008 22:27:28, 286463 bytes
| Driver: SynMomentum.mpg, 9/2/2008 22:27:28, 246230 bytes
| Driver: SynLinearVHScroll.mpg, 9/2/2008 22:27:28, 929103 bytes
| Driver: SynChiralVHScroll.mpg, 9/2/2008 22:27:28, 1620778 bytes
| Driver: SynTwoFingerVHScroll.mpg, 3/15/2009 20:44:00, 746464 bytes
| Driver: SynPivotRotate_ChiralRotate.mpg, 4/9/2009 04:04:14, 1142810 bytes
| Driver: SynThreeFingerFlick.mpg, 3/15/2009 20:44:00, 633621 bytes
| Driver: SynThreeFingersDown.mpg, 3/15/2009 20:44:00, 215907 bytes
| Driver: SynTPHelper.exe, 8/14/2009 09:53:52, 103720 bytes
| Driver: mouclass.sys, 7/13/2009 20:20:44, 41552 bytes
| Driver: SynTPCo4.dll, 8/14/2009 09:54:00, 120104 bytes
| Driver: WdfCoInstaller01009.dll, 8/6/2009 20:49:36, 1461992 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x13EE, 0x0003
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 18:45:08, 26112 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 07:30:12, 53120 bytes
| Driver: sermouse.sys, 7/13/2009 18:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 132.8 GB
Total Space: 228.2 GB
File System: NTFS
Model: ST9250827AS
Drive: D:
Model: Optiarc DVD RW AD-7563A ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 03:38:10, 108544 bytes
System Devices
Name: Mobile Intel(R) 965 Express Chipset Family
Device ID: PCI\VEN_8086&DEV_2A02&SUBSYS_0560107B&REV_03\3&33FD14CA&0&10
Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 8.14.0010.1930 (English), 9/23/2009 19:18:14, 4808192 bytes
Driver: C:\Windows\system32\igdumd32.dll, 8.14.0010.1930 (English), 9/23/2009 19:18:08, 3829760 bytes
Driver: C:\Windows\system32\igkrng400.bin, 9/11/2009 17:58:52, 2050952 bytes
Driver: C:\Windows\system32\iglhxs32.vp, 9/23/2009 19:45:20, 39440 bytes
Driver: C:\Windows\system32\iglhxo32.vp, 9/11/2009 17:20:32, 60015 bytes
Driver: C:\Windows\system32\iglhxc32.vp, 9/11/2009 17:20:32, 60226 bytes
Driver: C:\Windows\system32\iglhxg32.vp, 9/11/2009 17:20:32, 60254 bytes
Driver: C:\Windows\system32\iglhxa32.vp, 9/11/2009 17:20:32, 1090 bytes
Driver: C:\Windows\system32\iglhxa32.cpa, 9/11/2009 17:20:32, 1921265 bytes
Driver: C:\Windows\system32\hccutils.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:04, 94208 bytes
Driver: C:\Windows\system32\igfxsrvc.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:24, 51712 bytes
Driver: C:\Windows\system32\igfxsrvc.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 252952 bytes
Driver: C:\Windows\system32\igfxpph.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:42, 199680 bytes
Driver: C:\Windows\system32\igfxcpl.cpl, 8.14.0010.1930 (English), 9/23/2009 18:49:34, 119296 bytes
Driver: C:\Windows\system32\igfxcfg.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:50, 672792 bytes
Driver: C:\Windows\system32\igfxdev.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:00, 218112 bytes
Driver: C:\Windows\system32\igfxdo.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:10, 130048 bytes
Driver: C:\Windows\system32\igfxtray.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 141848 bytes
Driver: C:\Windows\system32\hkcmd.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 173592 bytes
Driver: C:\Windows\system32\igfxress.dll, 8.14.0010.1930 (English), 9/23/2009 18:48:52, 5702656 bytes
Driver: C:\Windows\system32\igfxpers.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 150552 bytes
Driver: C:\Windows\system32\igfxTMM.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:42, 257536 bytes
Driver: C:\Windows\system32\TVWSetup.exe, 1.00.0001.0000 (English), 9/23/2009 19:30:50, 8198680 bytes
Driver: C:\Windows\system32\igfxext.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 173080 bytes
Driver: C:\Windows\system32\igfxexps.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:36, 23552 bytes
Driver: C:\Windows\system32\oemdspif.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:38, 59392 bytes
Driver: C:\Windows\system32\igfxrara.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:08, 252416 bytes
Driver: C:\Windows\system32\igfxrchs.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 178176 bytes
Driver: C:\Windows\system32\igfxrcht.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 179712 bytes
Driver: C:\Windows\system32\igfxrdan.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 280576 bytes
Driver: C:\Windows\system32\igfxrdeu.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 303616 bytes
Driver: C:\Windows\system32\igfxrenu.lrc, 8.14.0010.1930 (English), 9/23/2009 18:48:52, 275968 bytes
Driver: C:\Windows\system32\igfxresp.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 303104 bytes
Driver: C:\Windows\system32\igfxrfin.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 281088 bytes
Driver: C:\Windows\system32\igfxrfra.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 303616 bytes
Driver: C:\Windows\system32\igfxrheb.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 249856 bytes
Driver: C:\Windows\system32\igfxrita.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 304640 bytes
Driver: C:\Windows\system32\igfxrjpn.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 206848 bytes
Driver: C:\Windows\system32\igfxrkor.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 205312 bytes
Driver: C:\Windows\system32\igfxrnld.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 299520 bytes
Driver: C:\Windows\system32\igfxrnor.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 280064 bytes
Driver: C:\Windows\system32\igfxrplk.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 287744 bytes
Driver: C:\Windows\system32\igfxrptb.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 289280 bytes
Driver: C:\Windows\system32\igfxrptg.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 294912 bytes
Driver: C:\Windows\system32\igfxrrus.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 291328 bytes
Driver: C:\Windows\system32\igfxrsky.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 282624 bytes
Driver: C:\Windows\system32\igfxrslv.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 277504 bytes
Driver: C:\Windows\system32\igfxrsve.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 282624 bytes
Driver: C:\Windows\system32\igfxrtha.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:20, 262656 bytes
Driver: C:\Windows\system32\igfxrcsy.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 282624 bytes
Driver: C:\Windows\system32\igfxrell.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 310784 bytes
Driver: C:\Windows\system32\igfxrhun.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 288256 bytes
Driver: C:\Windows\system32\igfxrtrk.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:20, 279040 bytes
Driver: C:\Windows\system32\ig4icd32.dll, 8.14.0010.1930 (English), 9/23/2009 18:58:12, 4104192 bytes
Driver: C:\Windows\system32\ig4dev32.dll, 8.14.0010.1930 (English), 9/23/2009 18:58:38, 2686976 bytes
Driver: C:\Windows\system32\igd10umd32.dll, 8.14.0010.1930 (English), 9/23/2009 19:09:58, 2551808 bytes
Driver: C:\Windows\system32\igdumdx32.dll, 8.14.0010.1930 (English), 9/23/2009 19:14:54, 536576 bytes
Driver: C:\Windows\system32\igfxCoIn_v1930.dll, 1.01.0017.0000 (English), 9/23/2009 19:27:44, 155648 bytes
Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A
Device ID: PCI\VEN_8086&DEV_283A&SUBSYS_0560107B&REV_04\3&33FD14CA&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/24/2011 21:57:58, 43008 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/24/2011 21:58:07, 284672 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/24/2011 21:58:37, 258560 bytes
Name: Intel(R) ICH8M LPC Interface Controller - 2815
Device ID: PCI\VEN_8086&DEV_2815&SUBSYS_0560107B&REV_04\3&33FD14CA&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 20:20:43, 13888 bytes
Name: Mobile Intel(R) PM965/GM965/GL960/GS965 Express Processor to DRAM Controller - 2A00
Device ID: PCI\VEN_8086&DEV_2A00&SUBSYS_00000000&REV_03\3&33FD14CA&0&00
Driver: n/a
Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_0560107B&REV_04\3&33FD14CA&0&EF
Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_F4\3&33FD14CA&0&F0
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 07:30:06, 153984 bytes
Name: Intel(R) ICH8M Ultra ATA Storage Controllers - 2850
Device ID: PCI\VEN_8086&DEV_2850&SUBSYS_0560107B&REV_04\3&33FD14CA&0&F9
Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.01.7600.16385 (English), 7/13/2009 20:20:36, 15424 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 20:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 20:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 07:29:12, 132992 bytes
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2835
Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_0560107B&REV_04\3&33FD14CA&0&D1
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.17586 (English), 3/24/2011 21:57:56, 24064 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_284B&SUBSYS_0560107B&REV_04\3&33FD14CA&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 04:59:29, 108544 bytes
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2834
Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_0560107B&REV_04\3&33FD14CA&0&D0
Name: Realtek PCIe FE Family Controller
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_0560107B&REV_01\4&37104257&0&00E0
Driver: C:\Windows\system32\DRIVERS\Rt86win7.sys, 7.46.0610.2011 (English), 6/10/2011 07:34:52, 394856 bytes
Driver: C:\Windows\system32\RtNicProp32.dll, 1.02.0000.0003 (English), 6/10/2011 07:34:52, 80416 bytes
Driver: C:\Windows\system32\RTNUninst32.dll, 1.00.0000.0005 (English), 6/10/2011 07:34:52, 100896 bytes
Name: Intel(R) ICH8 Family PCI Express Root Port 3 - 2843
Device ID: PCI\VEN_8086&DEV_2843&SUBSYS_0560107B&REV_04\3&33FD14CA&0&E2
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2832
Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_0560107B&REV_04\3&33FD14CA&0&EA
Name: Intel(R) ICH8 Family PCI Express Root Port 2 - 2841
Device ID: PCI\VEN_8086&DEV_2841&SUBSYS_0560107B&REV_04\3&33FD14CA&0&E1
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2831
Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_0560107B&REV_04\3&33FD14CA&0&E9
Name: Intel(R) PRO/Wireless 3945ABG Network Connection
Device ID: PCI\VEN_8086&DEV_4222&SUBSYS_10008086&REV_02\4&24F7F99B&0&00E1
Driver: C:\Windows\system32\DRIVERS\netw5v32.sys, 12.04.0001.0004 (English), 7/13/2009 17:02:51, 4231168 bytes
Name: Intel(R) ICH8 Family PCI Express Root Port 1 - 283F
Device ID: PCI\VEN_8086&DEV_283F&SUBSYS_0560107B&REV_04\3&33FD14CA&0&E0
Name: Intel(R) ICH8 Family USB Universal Host Controller - 2830
Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_0560107B&REV_04\3&33FD14CA&0&E8
Device ID: PCI\VEN_8086&DEV_2A03&SUBSYS_0560107B&REV_03\3&33FD14CA&0&11
Driver: n/a
Name: Intel(R) ICH8 Family SMBus Controller - 283E
Device ID: PCI\VEN_8086&DEV_283E&SUBSYS_0560107B&REV_04\3&33FD14CA&0&FB
Driver: n/a
Name: Intel(R) ICH8M-E/M SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_2829&SUBSYS_0560107B&REV_04\3&33FD14CA&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 8.09.0000.1023 (English), 6/4/2009 20:43:16, 330264 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3508.1109
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,15.00.0002.0072
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,15.00.0002.0072
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,15.00.0002.0072
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Rendering Devices:
HD Audio Headphone/Speakers,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Just to clarify, both test videos worked fine on your 32bit system?
Chris
yes, both of the 2 referenced HTML related videos played just fine on my 32bit laptop using IE9.
HTML5 video and Non-HTML5
And turning off hdw acceleration had no effect
And just as an fyi, one of my same town neighbors is also unable to play Flash videos lately.
Actually, one of those videos is HTML5, the other is Flash. So, your system is able to play Flash video content. That's good news.
Now the question, why won't this link (http://www.revolutiongolf.com/home/video/1775566388001) play? First, try clearing your browser cache, it's possible you have corrupt files here. Next, make sure you aren't running any third party extensions that might interfere. Finally, what version of the player do you have installed in both Firefox and IE?
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Firefox 15.0 is running the videos for me now - Firefox updated itself a couple of days ago & maybe that fixed the video problem in Firefox. IE9 still won't play the Flash videos. I just now downloaded & installed the latest Flash player - 11.4.something & it did not help even after restarting the browser. Clearing IE9 cache does not help. I also made sure that activex filtering was not active - it wasn't. As to 3rd party extensions in IE9 - well I don't know about those.
Still not working in IE. I'm up to IE11 now & running current W7 Home Prem 64bit with most current Flash, which is enabled. The stuff plays fine in current Firefox and current Chrome. I turned off filtering - did not help on this page: http://disneyjunior.com/lucky-you the pop-up page from the Disney page comes up in a white space with a big X that can be used to shut the page. In FF & Chrome the white space fills in with the proper stuff so that the child can start the game. If anyone knows how to fix the IE/Flash problem, please reply right away.
