Dear all,
PHP enquiry form submission some error is comes
"Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/en45/send_form_email.php on line 11"
Please help me
PHP goes like this
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>PHP Form</title>
</head>
<body><?php
if(isset($_POST['email'])) {
// EDIT THE 2 LINES BELOW AS REQUIRED
$email_to = "xyz@xyz.co.in";
$email_subject = "Your email subject line";
function died($error) {
// your error code can go here
echo "We are very sorry, but there were error(s) found with the form you submitted. ";
echo "These errors appear below.<br /><br />";
echo $error."<br /><br />";
echo "Please go back and fix these errors.<br /><br />";
die();
// validation expected data exists
if(!isset($_POST['first_name']) ||
!isset($_POST['email']) ||
!isset($_POST['telephone']) ||
!isset($_POST['company_name']) ||
!isset($_POST['comments'])) {
died('We are sorry, but there appears to be a problem with the form you submitted.');
$first_name = $_POST['first_name']; // required
$email_from = $_POST['email']; // required
$telephone = $_POST['telephone']; // not required
$last_name = $_POST['company_name']; // required
$comments = $_POST['comments']; // required
$error_message = "";
$email_exp = '/^[A-Za-z0-9._%-]+@[A-Za-z0-9.-]+\.[A-Za-z]{2,4}$/';
if(!preg_match($email_exp,$email_from)) {
$error_message .= 'The Email Address you entered does not appear to be valid.<br />';
$string_exp = "/^[A-Za-z .'-]+$/";
if(!preg_match($string_exp,$first_name)) {
$error_message .= 'The First Name you entered does not appear to be valid.<br />';
if(!preg_match($string_exp,$company_name)) {
$error_message .= 'The Last Name you entered does not appear to be valid.<br />';
if(strlen($comments) < 2) {
$error_message .= 'The Comments you entered do not appear to be valid.<br />';
if(strlen($error_message) > 0) {
died($error_message);
$email_message = "Form details below.\n\n";
function clean_string($string) {
$bad = array("content-type","bcc:","to:","cc:","href");
return str_replace($bad,"",$string);
$email_message .= "First Name: ".clean_string($first_name)."\n";
$email_message .= "Email: ".clean_string($email_from)."\n";
$email_message .= "Telephone: ".clean_string($telephone)."\n";
$email_message .= "Company Name: ".clean_string($company_name)."\n";
$email_message .= "Comments: ".clean_string($comments)."\n";
/* Redirect visitor to the thank you page */
header('Location:gt.html');
exit();
// create email headers
$headers = 'From: '.$email_from."\r\n".
'Reply-To: '.$email_from."\r\n" .
'X-Mailer: PHP/' . phpversion();
@mail($email_to, $email_subject, $email_message, $headers);
<!-- include your own success html here -->
Thank you for contacting us. We will be in touch with you very soon.
<?php
</body>
</html>
2 issues manojb
1) You have $last_name instead of $company_name in your php script (should be as below)
$company_name = $_POST['company_name']; // required
2) If you position the redirect where you have the form will not send the information as the php stops running at that point and never gets to the @mail command
exit();
Position it AFTER the @mail command.
Also the php script doesnt need the html wrapped around it. It can just go in a document without that.
Have your removed the html tags from around the form script?
<head>
</head>
<body>
</body>
</html>
something wrong from my side i dont know where it is gone wrong now error is
Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/send_form_email.php on line 12
I am really sorry osgood
PHP Code Updated
<head>
</head>
<body><?php
error_reporting(0);
$email_to = "xyz@rty.co.in";
die();
exit();
<?php
</body>
</html>
You still have not removed the html code from around the php script...try removing that.
<head>
</head>
<body>
</body>
</html>
osgood something like this
<?php
error_reporting(0);
die();
exit();
<?php
some error now
Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/send_form_email.php on line 5
My form like this
<form name="contactform" method="post" action="send_form_email.php">
<div class="field text">
<input type="text" name="first_name" maxlength="50" size="30" value="Name*:">
</div>
<input type="text" name="email" maxlength="80" size="30" value="E-mail*:">
</div>
<div class="clear"><!-- --></div>
<input type="text" name="telephone" maxlength="30" size="30" value="Phone.:">
</div>
<input type="text" name="company_name" maxlength="50" size="30" value="Company:">
</div>
<div class="field textarea"><div>
<textarea name="comments"></textarea>
</div></div>
<div class="submit">
<p>* - Required fields</p>
<input type="submit" value="Send" />
</div>
</form>
