Lisa_Florian
Installing debug version of Flash Player
Aug 4, 2012 4:44 AM
I want to install the debug version of Flash Player as a browser plugin. My problem is, that I can't even find a download link. A version for Chrome or IE 9 would be best, but if there isn't a debug player for those, I'd install another browser.
    Aug 4, 2012 7:30 PM   in reply to Lisa_Florian
    Aug 5, 2012 5:47 PM   in reply to Lisa_Florian
    You do uninstall the non-debug version first?
    Calculating status...
    Aug 7, 2012 10:47 AM   in reply to Pat Willener
    I'm having the same problem.  I've never had to uninstall the previous Flash player debugger for IE when upgrading.  Even so, even after uninstalling my existing IE ActiveX, the latest ActiveX debugger that is available on the download page cannot be installed.  I am quite "dead in the water" right now.  I cannot debug my Flex app.  Please fix ASAP.
    Aug 7, 2012 5:59 PM   in reply to Pauly W
    What does this mean?  Can you give some details?  Install log?
    Aug 7, 2012 7:08 PM   in reply to Pat Willener
    Sorry.  I will post the install logs when I return to my office tomorrow where I'm forced to run XP SP3.  The installer had no problem on my home PC running Win 7.
    Aug 8, 2012 4:40 AM   in reply to Pauly W
    Looks like your system has non-debugger Flash Player 11.3.300.268 version installed.
    Please check the existing version here: http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
    If Yes, please uninstall the version: http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
    Then proceed with the installation.
    Sunil
    Aug 8, 2012 7:08 AM   in reply to Pat Willener
    Here is more information regarding my problem.
    I am running 32-bit Windows XP SP3.
    I went to the "Find Version" website to ensure that the Flash player plugin for IE was uninstalled.  Here a screenshot:
    Then I went to the downloads page and downloaded the installer from the link labeled "Download the Windows Flash Player 11.3 ActiveX control content debugger (for IE) (EXE, 9.37 MB)".  Here is a screenshot:
    Running the installer produces the following dialog:
    Here are the log entries from today found in "C:\WINDOWS\system32\Macromed\Flash\FlashInstall.log":
    ?=O====== M/11.3.300.268 2012-08-08+13-50-28.322 ========
    0000 [I] 00000010 "C:\Documents and Settings\pwillarson\My Documents\Downloads\flashplayer_11_ax_debug (5).exe"
    0001 [E] 00001013
    =X====== M/11.3.300.268 2012-08-08+13-56-56.047 ========
    ?=O====== M/11.3.300.268 2012-08-08+14-04-05.879 ========
    0001 [E] 00001013
    =X====== M/11.3.300.268 2012-08-08+14-05-10.597 ========
    If there's any other information I can provide, please let me know.
    Thanks.
    - Paul W
    Aug 8, 2012 7:43 PM   in reply to Pauly W
    I just ran a quick test:
    • run the uninstaller (uninstall_flash_player.exe) 11.3.300.270 - successful
    • run the installer (flashplayer_11_plugin_debug.exe) 11.3.300.268 - successful
    • run the installer (flashplayer_11_ax_debug.exe) 11.3.300.269 - successful
    I don't know why you get that error.  Can you try to temporarily disconnect from the Internet while you run the installer?
    Aug 9, 2012 6:43 AM   in reply to Pat Willener
    Well, first I edited my hosts file so that adobe.com and www.adobe.com were pointed at the loopback address.  The error still occurred.  Then I ran Charles to see what HTTP requests the installer was making, which surprisingly was none.  So I'm not sure what the heck is happening on my system.  Like I said, at home I run Win7 and it doesn't happen.  I'm not the only one this is happening to either, as you can see by Lisa Florian's reply earlier in this thread.
    I'll try a few different things later today.
    Aug 10, 2012 6:20 AM   in reply to Pauly W
    I had the same issue. Here is how I solved it:
    I had a fresh Windows 7 with Adobe Flash (release) installed.
    I uninstalled it, no problem was issued.
    On the page http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html nothing was displayed => flash was uninstalled
    Installing either Flash 11.3 or 10.3 in debug version issued the same security error as described in this thread.
    I installed and ran the flash uninstaller pointed by Sunil (message 7) http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
    Once I did that, I was able to successfully install the debug version of the flash player.
    Aug 10, 2012 6:56 AM   in reply to apichery
    Thanks.  This worked.  I had no idea there was a difference between uninstalling through the "Add/Remove Programs" tool in Windows and using this uninstaller executable.  I appreciate the clarification.
