Flash player to iPhone streaming
Aug 9, 2012 3:07 PM
Tags: #video #live #server #ios #fms #4.5 #h264 #streaming #live_streaming
Hello
I was able to stream from FlashMediaEncoder to Ipad device (html5 video)
FME--->FMS---->IPAD : ok
Now I try to stream from flash player (flash11 with H264) to ipad but nothing happens.
Is it possible to stream from flashplayer (on PC, flash11) to IPAD ?
FlashPlayer11 (H264)--->FMS----->IPAD ?
Any link / clue  for that ?
regards
    Aug 10, 2012 1:39 AM   in reply to yarus3
    You can use Flash Player to publish H264 video that can be viewed on the iPad. Here are a few links :
    http://www.realeyes.com/blog/2011/10/31/new-in-flash-player-11-encodin g-live-video-to-h-264avc/
    http://videostreamingexpert.blog.com/2011/11/02/how-to-publish-h-264-l ive-stream-using-flash-player-11/
    You can check these to see if you've missed some step.
    Also, as Flash Player doesn't support publishing of audio as aac, you will be able to stream audio to your iPad.
    Apurva
    Aug 10, 2012 2:46 AM   in reply to yarus3
    Everytime you publish, you need to clear out the streams folder under livepkgr and the .stream file from under livepkgr/events/_definst_/liveevent. Can you try doing that then Restarting your server and trying again?
    Also, what is the url that you're using within <video> tag for playback?
    Aug 10, 2012 5:34 AM   in reply to yarus3
    You can use disk management to control how much of the live stream is to be kept on the disk. For example if you have it set to 15 minutes, then after 15 minutes server will start deleting the oldest fragments. See more here : http://help.adobe.com/en_US/flashmediaserver/devguide/WSeb6b7485f9649b f23d103e5512e08f3a338-8000.html#WSec225f632fa00875-23954b6f1300b641158 -8000
    Aug 10, 2012 7:15 AM   in reply to yarus3
    With the current FMS technology this is not possible. Transcoding is something which is on top of our mind, however if and when it'll happen is something that I cannot comment upon.
    What you can do is use an intermediate and external technology like ffmpeg to do the transcoding. Something like
    Flash Player -> FMS -> ffmpeg -> FMS -> iPad
    You can find some relevant information here : http://sonnati.wordpress.com/2011/08/30/ffmpeg-%E2%80%93-the-swiss-arm y-knife-of-internet-streaming-%E2%80%93-part-iv/
    Hope this helps.
    Apurva
    Aug 29, 2012 11:32 AM   in reply to Apurva Udaykumar
    Are you saying that after the live stream has ended and the encoder disconnected, the server will continue to serve obsolete files?
    That seems like a glaring mistake. What is wrong to cause this - can I program FMS to immediately delete the progressive files when the connection is ended?
    Joe
Bookmarked By (1)
