absolute flip bug CS5?
Aug 10, 2012 2:46 AM
Hi there,
I'm trying to check if an image has been flipped in InDesign CS5 using applescript:
tell application "Adobe InDesign CS5"
  activate
          set image_flip to absolute flip of the selection
  display dialog (image_flip as string)
end tell
If I flip the selected image horizontally only and run the script it returns 'horizontal'. If I flip the selected image vertically only and run the script it returns 'vertically'. However if i flip the selected image horizontally and vertically it returns 'none'. The dictionary for CS5 clearly states that it should be able to return 'horizontal and vertical/both':
absolute flip (none/horizontal/vertical/horizontal and vertical/both) : Indicates whether the image has been flipped independently of its parent object and, if yes, the direction in which the image was flipped.
Is this a bug with CS5 or am I doing something wrong?
Any help would be gratefully appreciated.
Nik
    Aug 10, 2012 7:19 AM   in reply to restless_mind
    I get the same using AppleScript and the ESTK…
    Aug 10, 2012 8:05 AM   in reply to restless_mind
    Yes that is what I thought too… Listed as r/w all is just wrongly documented me thinks?
    Aug 11, 2012 4:54 AM   in reply to Muppet Mark
    I guess that 'both' (or 'horizontal and vertical') is a set-only property, because when you flip an object horizontally and vertically this simply results in a 180° rotation angle, so the object is in fact not flipped at all (in the sense that the x-scale and the y-scale have the same sign).
    Marc
