I'm having bullet issues. I'm using a style called BulletList on some text. It looks fine in the RoboHelp application. It looks fine when I generate a chm file. But when I generate WebHelp, the bullet itself has moved to the right and appears superimposed over the second or third character of the text line.
Here's part of my CSS file:
p.BulletList {
margin-left: -20px;
margin-top: -1pt;
margin-bottom: 6pt;
list-style: url(bullet_graygreen_square.gif);
mso-list: l0 level1 lfo1;
LI.p-BulletList {
LI.kadov-P-CBulletList {
list-style: square;
Any thoughts? Thanks!
BTW, I'm using RoboHelp 9.0.1.232.
Your paragraph is indented 20 pixels to the left. You list element itself (that holds the bullet) is not indented. Try the following:
p.BulletList {
margin-top: -1pt;
margin-bottom: 6pt;
LI.p-BulletList {
margin-left: -20px;
This indents the entire list 20 pixels to the right. This should work for CHM and WebHelp alike.
Greet,
Willam
Hi Willam,
Thank you! That fixed it. Thanks for explaining as well. I see a few other styles in my CSS that have the same problem.
Tom
Great. Just post back if you encounter any other problems.
Greet,
Willam
I'm having this same issue. However, I don't know what style is used. It's a project I inherited and up to this point haven't had to work with css files. Where do I locate the css file used for the project?
You can have a CSS associated with topics (right-click on the Topic and check its Properties to see that CSS) or have 1 CSS applied to all topics when the help is created (check the SSL recipe in that scenario)
Where is the SSL receipe?
Sorry - Single Source Layouts - it's a pod you can turn on in your View - it will list all the types of output (WebHelp, FlashHelp, AIR Help, etc.)
I successfully changed the settings for each topic that had the bullet list and it's now displaying correctly in the output. Thanks a million!
