Global error handling
Aug 6, 2012 11:22 AM
Just curious: Has anyone successfully created a global error handler that would catch an error from any part of a real application based on Parsley, and on a few other well known frameworks?
    Aug 6, 2012 3:35 PM   in reply to Zolotoj
    Try the example in the doc and the one on my blog to see if they work for you.
    Aug 7, 2012 7:53 AM   in reply to Zolotoj
    It might apply if you have multiple SWFs including RSLs involved.  Every loaderInfo needs to be listening in order to catch some errors.
    Are you saying it works from a service but not from your own code?  How are you generating the error in your code?
    Aug 7, 2012 11:10 AM   in reply to Zolotoj
    I’m still unclear.  The error is not caught but the debugger player shows the error dialog?  Or nothing shows up?  What is on the call stack at the point of the error?
    Aug 7, 2012 2:36 PM   in reply to Zolotoj
    And what is on the call stack?
    Aug 7, 2012 3:40 PM   in reply to Zolotoj
    Can you make a simple test case that reproduces the problem?
    Aug 10, 2012 9:46 AM   in reply to Zolotoj
    If that were true, the Player’s error dialog would not show up.
    Aug 10, 2012 9:53 AM   in reply to Zolotoj
    Then that would be a reasonable explanation.  However, if I read over your prior post #6, my interpretation is that you are claiming that the dialog does show up.
    Aug 10, 2012 10:43 AM   in reply to Zolotoj
    Then yes, there is likely something else catching it.  Single-stepping will show you the catch if you have source for the catch.
