th72
Baffling Bullets
Jul 14, 2011 6:56 AM
I'm having bullet issues. I'm using a style called BulletList on some text. It looks fine in the RoboHelp application. It looks fine when I generate a chm file. But when I generate WebHelp, the bullet itself has moved to the right and appears superimposed over the second or third character of the text line.
Here's part of my CSS file:
p.BulletList {
margin-left: -20px;
margin-top: -1pt;
margin-bottom: 6pt;
list-style: url(bullet_graygreen_square.gif);
mso-list: l0 level1 lfo1;
LI.p-BulletList {
LI.kadov-P-CBulletList {
list-style: square;
Any thoughts? Thanks!
    Jul 14, 2011 7:07 AM   in reply to th72
    Your paragraph is indented 20 pixels to the left. You list element itself (that holds the bullet) is not indented. Try the following:
    p.BulletList {
    margin-top: -1pt;
    margin-bottom: 6pt;
    LI.p-BulletList {
         margin-left: -20px;
    This indents the entire list 20 pixels to the right. This should work for CHM and WebHelp alike.
    Greet,
    Willam
    Jul 14, 2011 7:38 AM   in reply to th72
    Great. Just post back if you encounter any other problems.
    Greet,
    Willam
    Aug 10, 2012 8:56 AM   in reply to th72
    I'm having this same issue.  However, I don't know what style is used.  It's a project I inherited and up to this point haven't had to work with css files.  Where do I locate the css file used for the project?
    Aug 10, 2012 9:10 AM   in reply to igcampbell@cox
    You can have a CSS associated with topics (right-click on the Topic and check its Properties to see that CSS) or have 1 CSS applied to all topics when the help is created (check the SSL recipe in that scenario)
    Aug 10, 2012 9:18 AM   in reply to Jeff_Coatsworth
    Where is the SSL receipe?
    Aug 10, 2012 10:02 AM   in reply to igcampbell@cox
    Sorry - Single Source Layouts - it's a pod you can turn on in your View - it will list all the types of output (WebHelp, FlashHelp, AIR Help, etc.)
    Aug 10, 2012 11:18 AM   in reply to Jeff_Coatsworth
    I successfully changed the settings for each topic that had the bullet list and it's now displaying correctly in the output.  Thanks a million!
