sadensmol
Window.open() dont show window
Aug 10, 2012 5:04 AM
Tags: #air #flex #window
Hello!
I just created simple application for showing wnidow onTop by event from server.
When main application in not active ( no focus ) window not appeared ( even creationComplete event not handles ).
Can you help me and advise?
Create window method is simple:
     wot = new UsersViewOnTopWindow();
     wot.open(false);
     wot.activate();
UsersViewOnTopWindow is
     <s:Window xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:s="library://ns.adobe.com/flex/spark"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          alwaysInFront="true"
                          showStatusBar="false"
                          maximizable="false"
                          minimizable="false"
                          resizable="false"
                          systemChrome="standard"
                          type="{NativeWindowType.UTILITY}"
                          focusEnabled="false"
                          visible="true"
    Aug 10, 2012 9:45 AM   in reply to sadensmol
    Did you verify your handler actually is getting called?
    Aug 10, 2012 3:22 PM   in reply to sadensmol
    Check size and position
    Aug 10, 2012 10:25 PM   in reply to sadensmol
    Set a breakpoint on LayoutManager.doPhasedInstantiation.   It should get called 3 to 12 times then creationComplete should fire.  If it keeps getting called over and over then you are in a “invalidation loop” where the window cannot figure out what size it should be.  Try locking down the size of the windor or its components to help resolve the sizes.
