There are two major issues with Flash Player in Chrome:
1) You often end up with multiple Flash Players enabled in chrome://plugins which can conflict. By disabling all but one of them, many problems go away (see this link for more details: http://www.lockergnome.com/media/2012/01/20/how-to-fix-shockwave-flash -crashes-in-google-chrome/).
2) When PepperFlash version 11.3.31.222 was released (around July 31, 2012) ip-multicast abilities stopped working and HDS video plays audio with black video. All of this worked fine in earlier versions of Flash Players in Chrome (assuming you took care of 1 above).
Sincerely,
Greg Pulier
Thank you for the post, gpulier.
I would just like to say i've found, "You often end up with multiple Flash Players enabled in chrome://plugins which can conflict" very true.
A lot of 'page(s) unresponsive'... The crash on websites i've found today - also on prior occasions - signalled a new Shockwave Flash Plugin, (ver: 11.3.31.225) had been automatically updated and dually enabled with my prefered older one.
Well, it's been updated, so i did enabled the new 11.3.31.225 on its own to test out - I do hope it's one that is stable! - but on Chrome you have to check 'chrome://plugins' quite frequently of late...
Chris,
I also thought that was the case but after very systematic tests on over 5 different computers I can conclude with a high degree of certainty that having multiple Flash Plugins enabled results in many issues (some of which I mentioned in my first post). So maybe it is a Chrome bug that is not completely ignoring the rest.
-Greg
Hi guys,
I'm currently working on a project where Stage3D comes into play and after reading, that some problems with the flash player in Google Chrome exist, I gave it a try and updated Chrome. Wow, after the update has finished I noticed a dramatic decrease in performance!
Here are my findings:
Having all player-versions marked as aktiv in chrome://plugins
Versions:
11.3.31.230
11,3,300,271
11,4,402,265
Chrome is using 11.3.31.230
I see in the Away3D stats that software rendering is used. Performance is terrible! 8-10 Frames
Deactivating 11.3.31.230
Chrome is using 11,3,300,271
I see in the Away3D stats that hardware acceleration is used (DirectX9). Performance is great! 58-60 Frames
Deaktivating 11,3,300,271
Chrome uses 11,4,402,265
As with 11,3,300,271 great performance.
I fear not a lot of people are changing manually their used flash plugin in Chrome and they will blame Flash for melting down their computers.
Wolfgang
Hi Wolfgang,
I'll follow up with your report with our internal Chrome team. In the meantime, would you mind opening a new bug report on this over at the Chromium bug database?
http://code.google.com/p/chromium/issues/entry
Chris
This slowdown might be related to this existing Chromium bug: https://code.google.com/p/chromium/issues/detail?id=142507
Hi Chris,
I've opened a new bug:
http://code.google.com/p/chromium/issues/detail?id=144583
kind regards
Wolfgang
Hi all!
I've just now tested on both Windows and Linux Chrome version 22.0.1229.79
this flash :
after a while (about 2 minutes) the following error message will appear:
Shockwave Flash has crashed...
No other browser and platfrom configuration can reproduce this crash, with this flash animation.
