Chaos after transferring LR4 catalogue to external hard drive
Aug 9, 2012 1:45 PM
Tags: #missing #files #external #hard #drive #lightroom4
Hello,
I transferred my LR4 catalogue from my Mac hard drive to an external drive. Then, I transferred my original photo files (2012, 2011 etc, with subfolders by date) to the external drive as well. Then I clicked "update folder location" on each main folder. In the catalogue under "All Photographs," most of my photos are offline and when I click "find missing photos" they're still offline. When I click the ? on an individual photo, LR can't find it. But when I find its folder on my own, LR won't allow me to select it. Is there any way I can fix this? Thanks!
    Aug 10, 2012 3:27 AM   in reply to alfieBB
    Don't start over. Relinking will work unless you deleted or individually renamed your images, which can make a close-to-insurmountable problem.
    Try this:
    Open the catalogue that you moved to the new drive. Double-clicking on it will work.
    In the Folders panel, right click on a folder with a ? on it. Choose 'Find missing folder'. In the box that comes up, navigate to where you moved the folder on the new drive and choose it.
    What happens? If if works for you, repeat the process. Doing it for parent folders will find the missing child folders, as well.
    Hal
    Aug 10, 2012 11:51 AM   in reply to alfieBB
    Alfie,
    When you click on the '?', LR opens a window to where it last knew the image to be. You ought to be able to then, in that window, navigate to where the image now is. Select that image.
    What happens when you try that?
    Hal
    Aug 10, 2012 3:55 PM   in reply to alfieBB
    Alfie,
    I created a missing image in my catalogue by moving it into a different folder:
    Lightroom Database-4 - Adobe Photoshop Lightroom - Library_2012-08-10_19-44-53.jpg
    When I click on the '?', I get this:
    Lightroom Database-4 - Adobe Photoshop Lightroom - Library_2012-08-10_19-47-12.jpg
    If I press Locate, I get this:
    The image I'm looking for isn't there because I moved it to a folder named temp on my desktop. I now navigate to that new folder in the window:
    Lightroom Database-4 - Adobe Photoshop Lightroom - Library_2012-08-10_19-52-16.jpg
    At this point I can click on the image and hit the Select button in the lower right.
    Where does this sequence of events stop working for you?
    Hal
