edp01
Impossible to install Flash Player for IE (impossible registering active X).
Jul 26, 2012 11:44 AM
Hello,
is 2 days I try to install in a PC Flash Player for IE 9 (Windows 7 64 BIT).
I try all but the installation fail when the installation try to register the ocx!
I try to register the ocx also manually (with regsvr32 from prompt) but I have always the error 8002801C that you can see below (I paste the log of installation, you can see the problem).
LOG OF INSTALLATION:
=O====== M/11.3.300.268 2012-07-26+17-55-43.403 ========
0000 [I] 00000010 "C:\Users\TEST.DOMAIN\AppData\Local\Temp\install_flash_player_ax.exe" -install -iv 8 -au 0
0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005 [I] 00000011 1
0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx
0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.e xe
0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.d ll
0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0012 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0013 [W] 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx 8002801C
0014 [I] 00000018
0015 [E] 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx 8002801C
=X====== M/11.3.300.268 2012-07-26+17-55-48.145 ========
Please note that installation in Firefox work fine (because the installation dont try to register ocx, I think) and Flash Palyer in Firefox work fine also.
I have control all the permission but I see other user have my problem.
This is crazy, as had say another user!!!!
Please can you help me?
  • Chris Campbell
    May 4, 2010
    Jul 26, 2012 3:03 PM   in reply to edp01
    I'm assuming that you've tried to do a clean install, so I think the next step would be to try and fix your file/folder/registry permissions.  Can you try the steps outlined in this FAQ and let me know how it goes?
    How do I fix Windows permission problems with Flash Player?
    Chris
    Jul 27, 2012 3:19 AM   in reply to edp01
    I use Flash Player 11.3.300.268 on Windows 7 64-bit with IE9 (both 32-bit & 64-bit editions).
    Can I ask you to try a different installer (but no guarantee that it will work better):
    download the MSI installer from http://www.adobe.com/products/flashplayer/distribution3.html and save it to disk, then close all browser windows and run the downloaded installer.
    Make sure you run the installer as an Administrator user.
    Jul 27, 2012 8:12 PM   in reply to edp01
    If the SubInACL procedure did not clear the permission problem, then we need to find out manually where exactly the permission is wrong.  The best tool for this is Process Monitor.
    Can you try the following:
    1. download ProcMon from http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
    2. extract the files from ProcessMonitor.zip
    3. uninstall Flash Player using the uninstaller from http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
    4. delete all files and folders in
      • C:\Windows\system32\Macromed\Flash
      • C:\Windows\syswow64\Macromed\Flash
    5. download the latest install_flash_player_ax.exe from http://helpx.adobe.com/content/help/en/flash-player/kb/installation-pr oblems-flash-player-windows.html#main-pars_header if you do not already have it
    6. start Procmon64.exe
    7. on the Process Monitor Filter panel, specify
      • Display entries matching these: Process Name is install_flash_player_ax.exe; click [Add], then [OK]
    8. run install_flash_player_ax.exe
    9. in ProcMon, click File, then Save...
    Now you can try to find yourself if you can see what's going wrong, or you can send me the Logfile.PML file from ProcMon to my email address.  I will send you a PM with my email address.
    If that ProcMon log file is larger than 2MB or so, can you zip it up before sending it to me?
    Sorry for making things so complicated, but I don't know any other way to find out what's wrong.
  • Chris Campbell
    May 4, 2010
    Jul 27, 2012 9:27 PM   in reply to Pat Willener
    You might also want to try to create a new, temporary user account and see if you can get it registered there.  This is not normal behavior, and very rare which leads me to believe that we're dealing with permissions in your user account or possibly at a lower level.
    Out of curiosity, when you tried to register the activex by hand, did you do this from an elevated (open as administrator) command prompt?
    Aug 6, 2012 8:36 PM   in reply to edp01
    I have received your ProcMon log, but didn't have time to look at it yet.
    Question: you write that the problem returned; what problem, exactly?  Originally you were unable to register the ActiveX ocx, but now what is the problem?
    Aug 8, 2012 10:42 PM   in reply to edp01
    I'm attaching your ProcMon log file to this post; hopefully someone from the installer team can have a look at it.
  • Chris Campbell
    May 4, 2010
    Aug 9, 2012 6:58 PM   in reply to Pat Willener
    Thanks for the log, I've got it at the top of my todo list tomorrow.
  • Chris Campbell
    May 4, 2010
    Aug 10, 2012 12:01 PM   in reply to Chris Campbell
    Could you do steps 1 - 5 in this post:
    http://forums.adobe.com/message/4311497#4311497
    And post the log output or email it to me at ccampbel@adobe.com?
    Chris
  • Chris Campbell
    May 4, 2010
    Aug 27, 2012 6:17 PM   in reply to edp01
    I've just updated the reset_fp11.bat script in the following FAQ.  Would you mind giving it a try again?
  • Chris Campbell
    May 4, 2010
    Aug 29, 2012 6:08 PM   in reply to edp01
    When you tried to register by hand, was the command prompt elevated to admin?
    It would be interesting to try these steps when registering:
    1. Make sure that you are logged into the computer as local Administrator, or are part of the local Administrator group.
    2. To identify which registry key is causing the problem use Regmon (a freeware tool published by SysInternals). Use Regmon to capture all registry access when regsvr32 is run. If an ‘OpenKey’ request fails with ‘Access Denied’ (which is listed by Regmon as ‘ACCDENIED’) then run regedt32 and check the permissions on that registry key. If necessary change the permissions on the key to grant local Administrators ‘Full Control’.
    3. Finally, try registering the COM object again.
    Aug 29, 2012 8:39 PM   in reply to Chris Campbell
    Chris,
    a procmon log from this user is attached in my post #11.
    Jan 3, 2013 8:44 PM   in reply to edp01
    I was able to resolve this by manually registering the required ocx file via a command prompt with administrative privileges. I am running Win7-x64. Steps were:
    1. Install Flash Player (you will receive error message about failing to register).
    2. Start command prompt with administrative priviliges (Right click on Command Prompt shortcut in Start Menu and select "Run As Administrator")
    3. Change to folder containing ocx file ("cd C:\Windows\SysWOW64\Macromed\Flash")
    4. Register ocx file ("regsvr32 Flash32_XXX.ocx" - replace XXX with appropriate file name).
    However, I suspect this is just treating the symptoms, rather than the cause, and the problem will probably reoccur when a new Flash update arrives.
    Trenton
