RoboAnz
Snap Empower Problem
Jul 13, 2012 6:39 AM
Tags: #snap #empower
May be a long shot reporting this issue here but maybe someone has an idea.
I'm using Snap Empower v 1.0 and trying to insert a .SWF published from Snap into Captivate 5.
The weird thing is, all text contained in the SWF does not appear in Captivate when I publish the Captivate project. Images display and buttons work, etc. Doesn't seem to be a font issue.
The SWF plays fine using the Flash player and when the Captivate page is previewed.
Any ideas?
    Jul 13, 2012 8:27 AM   in reply to RoboAnz
    I don't know if this is the problem, but we use Snap by Lectora (not Empower).  The last time I tried to import something from Snap to Cp, I received a warning that the Snap swf was AS2 and Cp5/5.5 uses AS3.
    I poked around in Snap but didn't see a place to set AS2 or AS3.  I'm not sure how you could check to see if your empower swf is as2 or as3, other than maybe opening it in adobe flash.
    hope that helps.
    Aug 6, 2012 11:01 AM   in reply to RoboAnz
    Thanks for the plug RoboAnz!
    Aug 8, 2012 8:04 PM   in reply to Jim Leichliter
    Is that the Web Widget currently in beta or do you mean a different one.
    Aug 10, 2012 12:09 PM   in reply to RoboAnz
    @RoboAnz:  Thanks for the plug!  The Cp 6.0 version of the web page widget should be out very soon... with HTML5 support.
