Media Encoder CS6 always crashes when quitting
Aug 10, 2012 1:20 PM
Tags: none (add) #cs6 #mediaencoder #cs6_media_encoderI'm running Media Encoder CS6 (6.0.1.31) and it seems to open and a run fine but it always crashes when quitting the app and prompts to send a report.
The installer was created using AAMEE and I need to deploy this to all of our users so unfortunately a simple suggestion of "uninstall and reinstall" won't work for us. I need a solution that will work for the network deployed version we're using.
Process: Adobe Media Encoder CS6 [63329]
Path: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/MacOS/Adobe Media Encoder CS6
Identifier: com.adobe.ame.application
Version: 6.0.1 (6.0.1.31)
Code Type: X86-64 (Native)
Parent Process: launchd [614]
Date/Time: 2012-08-10 13:15:23.660 -0700
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 940751 sec
Crashes Since Last Report: 21
Per-App Interval Since Last Report: 442 sec
Per-App Crashes Since Last Report: 5
Anonymous UUID: D9A9318A-8CB0-44A9-842F-B0CADAD966FC
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x00007fff80a940b6 __kill + 10
1 libSystem.B.dylib 0x00007fff80b349f6 abort + 83
2 libstdc++.6.dylib 0x00007fff8886d5d2 __tcf_0 + 0
3 libobjc.A.dylib 0x00007fff83a60b4d _objc_terminate + 120
4 libstdc++.6.dylib 0x00007fff8886bae1 __cxxabiv1::__terminate(void (*)()) + 11
5 libstdc++.6.dylib 0x00007fff8886bb16 __cxxabiv1::__unexpected(void (*)()) + 0
6 libstdc++.6.dylib 0x00007fff8886bb1c __cxxabiv1::__unexpected(void (*)()) + 6
7 libstdc++.6.dylib 0x00007fff8886b554 __cxa_call_unexpected + 65
8 ...adobe.AMEFrontend.framework 0x00000001051d7580 AME::Frontend::AMEFrontendMain::Release() + 0
9 ...adobe.AMEFrontend.framework 0x00000001051d40e5 AME::Frontend::TerminateAMEFrontend() + 37
10 com.adobe.ame.application 0x00000001000239db AME::RunTheApp(exo::app::AppInitArgs&, std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&) + 3675
11 com.adobe.ame.application 0x0000000100049d56 main + 358
12 com.adobe.ame.application 0x000000010001791c start + 52
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff80a5ec0a kevent + 10
1 libSystem.B.dylib 0x00007fff80a60add _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff80a607b4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff80a602de _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff80a5fc08 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff80a5faa5 start_wqthread + 13
Thread 2:
0 libSystem.B.dylib 0x00007fff80a80a6a __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff80a84881 _pthread_cond_wait + 1286
2 ...ple.CoreServices.CarbonCore 0x00007fff81e85d87 TSWaitOnCondition + 118
3 ...ple.CoreServices.CarbonCore 0x00007fff81df4ff8 TSWaitOnConditionTimedRelative + 177
4 ...ple.CoreServices.CarbonCore 0x00007fff81deeefb MPWaitOnQueue + 215
5 ...obe.ASLFoundation.framework 0x00000001006301f0 ASL::(anonymous namespace)::TaskProc(void*) + 160
6 ...ple.CoreServices.CarbonCore 0x00007fff81dc70d1 PrivateMPEntryPoint + 63
7 libSystem.B.dylib 0x00007fff80a7efd6 _pthread_start + 331
8 libSystem.B.dylib 0x00007fff80a7ee89 thread_start + 13
Thread 3:
5 com.adobe.dvacore.framework 0x0000000100263c04 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr< dvacore::threads::AllocatedFunctionT<boost::function<void ()()> > >&, int) + 200
6 com.adobe.dvacore.framework 0x0000000100260f03 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
7 com.adobe.dvacore.framework 0x000000010025e5f3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 163
8 ...obe.boost_threads.framework 0x0000000100194ace thread_proxy + 158
9 libSystem.B.dylib 0x00007fff80a7efd6 _pthread_start + 331
10 libSystem.B.dylib 0x00007fff80a7ee89 thread_start + 13
Thread 4:
Thread 5:
1 ...dobe.dvatransport.framework 0x000000010080bb12 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_op eration>&) + 240
2 ...dobe.dvatransport.framework 0x0000000100815cda boost::asio::detail::task_io_service::do_one(boost::asio::detail::sco ped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 512
3 ...dobe.dvatransport.framework 0x0000000100816067 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 291
4 ...dobe.dvatransport.framework 0x0000000100802bbd SkyConnectionEnv::MainLoop() + 129
5 ...dobe.dvatransport.framework 0x0000000100802c3b SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 ...obe.boost_threads.framework 0x0000000100194ace thread_proxy + 158
Thread 6:
2 ...dobe.dvatransport.framework 0x0000000100815c4b boost::asio::detail::task_io_service::do_one(boost::asio::detail::sco ped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 369
4 ...dobe.dvatransport.framework 0x000000010080382a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver _service_base::work_io_service_runner>::run() + 42
5 ...dobe.dvatransport.framework 0x0000000100806833 boost_asio_detail_posix_thread_function + 19
6 libSystem.B.dylib 0x00007fff80a7efd6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff80a7ee89 thread_start + 13
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
1 libSystem.B.dylib 0x00007fff80a808f9 nanosleep + 148
2 ...adobe.ScriptLayer.framework 0x0000000104c3a14b ScObjects::Thread::sleep(unsigned int) + 59
3 ...adobe.ScriptLayer.framework 0x0000000104c27749 ScObjects::BridgeTalkThread::run() + 169
4 ...adobe.ScriptLayer.framework 0x0000000104c3a496 ScObjects::Thread::go(void*) + 166
5 libSystem.B.dylib 0x00007fff80a7efd6 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff80a7ee89 thread_start + 13
Thread 13:
Thread 14:
Thread 15:
0 libSystem.B.dylib 0x00007fff80a5fa2a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff80a5fe3c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff80a5faa5 start_wqthread + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fff700352f8 rcx: 0x00007fff5fbff298 rdx: 0x0000000000000000
rdi: 0x000000000000f761 rsi: 0x0000000000000006 rbp: 0x00007fff5fbff2b0 rsp: 0x00007fff5fbff298
r8: 0x00007fff70038a60 r9: 0x000000010b174b30 r10: 0x00007fff80a900fa r11: 0x0000000000000206
r12: 0x00000001002f1520 r13: 0x000000010b17ecc0 r14: 0x00007fff83a60ad5 r15: 0x0000000107b62e10
rip: 0x00007fff80a940b6 rfl: 0x0000000000000206 cr2: 0x0000000100232d94
Binary Images:
0x100000000 - 0x1000acfff +com.adobe.ame.application 6.0.1 (6.0.1.31) <144FDE11-9F9D-EC5E-8E83-A5128F62CAB7> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/MacOS/Adobe Media Encoder CS6
0x100171000 - 0x100178fff +com.adobe.boost_date_time.framework 6.0.1 (6.0.1.0) <5F8E84B7-FD9E-0300-BC48-C367144CA4ED> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boos t_date_time
0x100193000 - 0x1001a2fff +com.adobe.boost_threads.framework 6.0.1 (6.0.1.0) <CDEED27E-3007-8823-8E75-E1D592D77EEC> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads
0x1001c3000 - 0x100393ff7 +com.adobe.dvacore.framework 6.0.1 (6.0.1.0) <0A8D28DC-B11B-F4AD-6A41-786311779094> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x1005a1000 - 0x1005cbff7 +com.adobe.dvamediatypes.framework 6.0.1 (6.0.1.0) <9E95E981-0165-08E0-C0A2-FE89849E4968> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamed iatypes
0x1005ff000 - 0x100600ff7 +com.adobe.PRM.framework 6.0.1 (6.0.1.0) <396FB005-CD61-85AE-59CC-624D776263A8> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x100606000 - 0x100668ff7 +com.adobe.ASLFoundation.framework 6.0.1 (6.0.1.0) <B85C5640-594B-DA77-2FC5-C81E7C77912D> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFou ndation
0x10075f000 - 0x10077cfff +com.adobe.ASLMessaging.framework 6.0.1 (6.0.1.0) <A70D371F-DF5B-DB74-847B-4964570A7494> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMess aging
0x1007aa000 - 0x1007abff7 +com.adobe.Memory.framework 6.0.1 (6.0.1.0) <3921E82B-9424-D790-0F03-F668409B2B0C> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x1007b2000 - 0x1007c1ff7 +com.adobe.ASLUnitTesting.framework 6.0.1 (6.0.1.0) <E57F7785-9AF8-45DE-7953-30AC75E56FA0> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUn itTesting
0x1007dd000 - 0x1007e0fff +com.adobe.boost_system.framework 6.0.1 (6.0.1.0) <B3159CB0-DABC-B44B-D7F8-3F7959628CFC> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_s ystem
0x1007e6000 - 0x10084cfff +com.adobe.dvatransport.framework 6.0.1 (6.0.1.0) <76FAE312-EAE4-D56D-2914-E413999A5148> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatran sport
0x1008cd000 - 0x100909fff +com.adobe.dvamarshal.framework 6.0.1 (6.0.1.0) <F69C844B-A0AE-1ED9-47FD-964DB0FF2FF6> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarsha l
0x10099b000 - 0x100b81fe7 +com.adobe.dynamiclink.framework 6.0.1 (6.0.1.0) <CE161C54-B05E-E71E-630A-4047B57E9C94> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamicl ink
0x100d84000 - 0x100deafe7 +com.adobe.MediaFoundation.framework 6.0.1 (6.0.1.0) <00067527-36E7-A8EE-975B-7946FC74362B> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Medi aFoundation
0x100e73000 - 0x100f1ffff +com.adobe.AudioRenderer.framework 6.0.1 (6.0.1.0) <8BB5C102-7D7D-B627-BB84-B63125CF9025> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioR enderer
0x100fdf000 - 0x101009fff +com.adobe.dvacaptioning.framework 6.0.1 (6.0.1.0) <7D41BE3E-4715-250F-66FA-A3C8585D657F> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacap tioning
0x10103f000 - 0x101096fff +com.adobe.dvatemporalxmp.framework 6.0.1 (6.0.1.0) <70F90095-783D-EC67-D04A-43EF39D170CF> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvate mporalxmp
0x1010ca000 - 0x1010d6fff +com.adobe.boost_signals.framework 6.0.1 (6.0.1.0) <07C8EE58-DB1A-E345-A39A-E489892326FC> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_ signals
0x1010ee000 - 0x101148fff +com.adobe.dvametadata.framework 6.0.1 (6.0.1.0) <9C8327BF-46CE-9F92-3693-48C03809F947> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametad ata
0x1011e5000 - 0x101245ff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.3 -c 11 (66.146729) <88C23D1F-50F3-13DD-7C60-F9530B29513E> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x10124f000 - 0x101306fef +com.adobe.AdobeXMPFiles Adobe XMP Files 5.4 -f 51 (66.146729) <D961D69F-E61B-BFB0-81D4-7924221B8E1B> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
0x101339000 - 0x102171ff7 +com.adobe.Backend.framework 6.0.1 (6.0.1.0) <D17E4A5A-CE1C-C7A1-3AC5-2333B3570757> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x102bfb000 - 0x102c17fff +com.adobe.AMEAppFoundation.framework 6.0.1 (6.0.1.31) <0E21D182-B711-5015-69CD-EF4811B8971D> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AME AppFoundation
0x102c4d000 - 0x1030b5ff7 +com.adobe.dvaui.framework 6.0.1 (6.0.1.0) <747DD574-C1E4-6908-4D4F-49EF9F59714C> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x103627000 - 0x1036dfff7 +com.adobe.dvaworkspace.framework 6.0.1 (6.0.1.0) <9C220D42-D4EA-50AB-6CA8-A5EC7E6635A5> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
0x1037ed000 - 0x1038bffff +com.adobe.exo.framework 6.0.1 (6.0.1.0) <27F07C1F-0E9F-FB4F-847E-AD7AFC1BFEB2> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x103a24000 - 0x103a6dff7 +com.adobe.MLFoundation.framework 6.0.1 (6.0.1.0) <A651E996-18B7-F5ED-962E-D3B90A324F0D> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFound ation
0x103ade000 - 0x103c21ff7 +com.adobe.ImageRenderer.framework 6.0.1 (6.0.1.0) <318EADE7-7FDE-47F7-C29A-EC09ACFC9D86> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageR enderer
0x103d47000 - 0x103d9cff7 +com.adobe.VideoFrame.framework 6.0.1 (6.0.1.0) <56A00AA2-12FA-61AC-4D8A-71F84787862A> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFram e
0x103dec000 - 0x103e28fff +com.adobe.PluginSupport.framework 6.0.1 (6.0.1.0) <72997515-0968-39C8-53B8-A198DA937788> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/PluginSupport.framework/Versions/A/Plugin Support
0x103e6e000 - 0x103e9afff +com.adobe.SweetPeaSupport.framework 6.0.1 (6.0.1.0) <10E99E6D-4AB9-AFA5-E898-2A42FD88A76C> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/Swee tPeaSupport
0x103ed3000 - 0x104028fff +com.adobe.VideoRenderer.framework 6.0.1 (6.0.1.0) <8D093BB0-C6AF-FA6C-580D-1C47CD6AD399> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoR enderer
0x104140000 - 0x104183fff +com.adobe.AudioSupport.framework 6.0.1 (6.0.1.0) <CE60FC27-B313-2237-1536-0201A311FA05> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSu pport
0x1041cd000 - 0x1041d0fff +com.adobe.MediaUtils.framework 6.0.1 (6.0.1.0) <CFB8D7CD-53A4-93B9-CC3A-B3B1369FD330> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtil s
0x1041d7000 - 0x104368fff +com.adobe.ImporterHost.framework 6.0.1 (6.0.1.0) <631E9216-4B34-8117-DBA1-CECE565A55BE> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ImporterHost.framework/Versions/A/Importe rHost
0x1044e8000 - 0x1045daff7 +com.adobe.ExporterHost.framework 6.0.1 (6.0.1.0) <6D8E6959-4CD4-A0E6-3CE5-4121321E5810> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ExporterHost.framework/Versions/A/Exporte rHost
0x1046cb000 - 0x1047bcff7 +com.adobe.VideoFilterHost.framework 6.0.1 (6.0.1.0) <910CB862-6A10-5364-E4D1-EF2AD39BDB74> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/Vide oFilterHost
0x10487c000 - 0x104947fff +com.adobe.AMEWrapper.framework 6.0.1 (6.0.1.31) <BF5975F1-D530-88D6-ED54-8AE7FE633815> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrappe r
0x104a11000 - 0x104b10ff7 +com.adobe.EncoderHost.framework 6.0.1 (6.0.1.0) <0627BB90-8531-0D0A-2979-585D7D131291> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderH ost
0x104c06000 - 0x104c73fff +com.adobe.ScriptLayer.framework 6.0.1 (6.0.1.31) <29441A08-3FD4-496C-2E26-C2BE15C69957> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLa yer
0x104cbf000 - 0x104d6dfef +com.adobe.AdobeScCore ScCore 4.2.12 (4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
0x104daa000 - 0x104e67fff +com.adobe.AdobeExtendScript ExtendScript 4.2.12 (4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
0x104eb1000 - 0x104f9fff7 +com.adobe.Batch.framework 6.0.1 (6.0.1.31) <7E2C5857-7D8E-9156-18DC-7744D74DDFFB> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
0x1050e9000 - 0x10512efff +com.adobe.dynamiclinkui.framework 6.0.1 (6.0.1.0) <8ADC9D0A-DD40-F1E3-BAEA-8F61B173B996> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynami clinkui
0x10519d000 - 0x1053fbfff +com.adobe.AMEFrontend.framework 6.0.1 (6.0.1.31) <B3FC2A4D-1CEA-5BED-E722-66FFC79C8AD7> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AMEFrontend.framework/Versions/A/AMEFront end
0x1056ae000 - 0x1056b4fff +com.adobe.AppServices.framework 6.0.1 (6.0.1.31) <DD9CD80C-E40F-4597-8A1A-1B09B719B2AB> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServi ces
0x1056c2000 - 0x1058b8ff7 +com.adobe.SettingsUI.framework 6.0.1 (6.0.1.31) <ECF20FB9-1555-A8A3-E371-62C6BD9C5F56> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsU I
0x105b15000 - 0x105b7bfff +com.adobe.DynamicLinkMedia.framework 6.0.1 (6.0.1.0) <4F952317-1A77-D5B8-EF12-8E9D237A5030> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/Dyn amicLinkMedia
0x105c2c000 - 0x105c68fff +com.adobe.AMEDynamicLinkClient.framework 6.0.1 (6.0.1.31) <915DD290-76AC-B820-47F9-E3011610836C> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AMEDynamicLinkClient.framework/Versions/A /AMEDynamicLinkClient
0x105cdd000 - 0x105de5ff7 +com.adobe.dvametadataDB.framework 6.0.1 (6.0.1.0) <72A230C3-FE9C-A338-E85B-B2B699F10D28> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvamet adataDB
0x105e43000 - 0x105eabfff +com.adobe.AMEDynamicLinkServer.framework 6.0.1 (6.0.1.31) <073B4741-0D4B-D26A-29A9-0279205B40BA> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AMEDynamicLinkServer.framework/Versions/A /AMEDynamicLinkServer
0x105f80000 - 0x105fc2fff +com.adobe.WatchFolder.framework 6.0.1 (6.0.1.31) <54580988-8B84-706A-3312-859968ED6C7A> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/WatchFolder.framework/Versions/A/WatchFol der
0x106034000 - 0x1060a3fff +com.adobe.QT32Client.framework 6.0.1 (6.0.1.0) <6A68A901-F01F-FAEA-13F4-94CD0A0F18E9> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Clien t
0x106139000 - 0x106209fef +com.adobe.dvaeve.framework 6.0.1 (6.0.1.0) <08527E52-45F2-AA58-437A-D0D5DFAE2290> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x106381000 - 0x1063ddff7 +com.adobe.MediaCoreUI.framework 6.0.1 (6.0.1.0) <D6542BEE-2949-4A69-4BCC-43E1A9618CB2> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCor eUI
0x106440000 - 0x106524fe7 +com.adobe.amtlib amtlib 6.0.0.93 (6.0.0.93) <3FB67F73-A24E-789B-0BAE-8FB3BE025C11> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x106535000 - 0x10680dfe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x10698e000 - 0x1069b2fe7 +com.mainconcept.mc.enc.dv 9.1 (9.1.6.7339) <F977AE49-D347-16CB-0AE7-D3B10569BC69> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
0x1069c6000 - 0x1069c6ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <424E55F7-B6DA-0F5C-E56B-9ECB4A2E6BA8> /usr/lib/libmx.A.dylib
0x1069c9000 - 0x1069f5fff +com.adobe.amefoundation.framework 6.0.1 (6.0.1.0) <0B026B3E-C02F-EAAA-E23F-01613BDAAE1F> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefou ndation
0x106a39000 - 0x106a6aff7 +com.adobe.ameproperties.framework 6.0.1 (6.0.1.0) <A79CCABA-3629-DA4A-0F2C-E958D3AF703E> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ameproperties.framework/Versions/A/amepro perties
0x106ab5000 - 0x106adafff +com.adobe.PostEncodeHost.framework 6.0.1 (6.0.1.31) <E94F9A83-038D-AB4E-FF14-C46544A3ECDA> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostE ncodeHost
0x106b0f000 - 0x106b7dfef +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
0x106bd1000 - 0x106bd5ff7 +com.adobe.AdobeCrashReporter 6.0 (6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
0x106bdb000 - 0x106be1ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <4BA195A7-49B8-A9B7-B510-CA5CE4F03AFB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x106be8000 - 0x106c06fff +com.adobe.BIB AdobeBIB 1.2.02.19243 (1.2.02.19243) <6C6431BE-06BA-55A7-87FA-46EFB6ED0FAF> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x106c0d000 - 0x106c66fff +com.adobe.BravoInitializer.framework 6.0.1 (6.0.1.0) <58B04D64-668E-AF47-3EFA-99B6FBC4F207> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/Bra voInitializer
0x106ce0000 - 0x106e59fff +com.adobe.ACE AdobeACE 2.19.18.19243 (2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x106e6c000 - 0x1071e9fff +com.adobe.AGM AdobeAGM 4.26.17.19243 (4.26.17.19243) <19B59987-1020-E125-DC86-EA48FC81A890> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x107255000 - 0x1075b6fef +com.adobe.CoolType AdobeCoolType 5.10.31.19243 (5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
0x107603000 - 0x10761dff7 +com.adobe.ahclientframework 1.7.0.56 (1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x107626000 - 0x1076baff7 +com.adobe.dvametadataUI.framework 6.0.1 (6.0.1.0) <DBB7B233-2DD5-032C-573F-0C238284F504> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvamet adataUI
0x107790000 - 0x1077b8ff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <223EFB56-968F-7D00-05F1-4594F2144C0F> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
0x107d00000 - 0x107d38ff7 +libMOG_Framework.dylib.2.2.4 ??? (???) <7A97623B-F09F-CA33-B9EA-1202FA569605> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMOG_Framework.dyli b.2.2.4
0x107d57000 - 0x107d60ff7 +libMXF_SDK_GenericContainer_AES3.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AES3.dylib.4.4.3
0x107d68000 - 0x107d72fff +libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AES3_S302M.dylib.4.4.3
0x10b7e8000 - 0x10b7eafef com.apple.textencoding.unicode 2.3 (2.3) <D95D796E-4D14-665C-F439-4652C0CD453F> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x10b7f4000 - 0x10b7fafff +libMXF_SDK_GenericContainer_AVI.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AVI.dylib.4.4.3
0x10d55b000 - 0x10d56cfff +com.adobe.ExporterMPEGPreview.framework 6.0.1 (6.0.1.0) <795705A3-78FC-07DF-6EA5-7E84FC322E15> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/ExporterMPEGPreview.bundle/Contents/ MacOS/ExporterMPEGPreview
0x10d57f000 - 0x10d58effd +com.mainconcept.mc.enc.mpa 9.1 (9.1.6.7339) <F18E0114-7877-9C34-39D4-4421D8F16278> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/9/mc_enc_mp a
0x10d5ab000 - 0x10d5bfff7 +com.adobe.QTParser.framework 6.0.1 (6.0.1.0) <38376362-6121-AE48-2744-FDDBFB76EAC4> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
0x10d5d3000 - 0x10d5d8fff +libMXF_SDK_Modules_DataIO.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_Modules_Da taIO.dylib.1.3.3
0x11e9d2000 - 0x11e9dbfff +libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEGPS.dylib.4.4.3
0x1200b3000 - 0x1200bfff7 +libMXF_SDK_GenericContainer_D10.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_D10.dylib.4.4.3
0x1200c7000 - 0x1200e1fef +libMXF_SDK_GenericContainer_DV.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_DV.dylib.4.4.3
0x1200f3000 - 0x1200f9fff +libMXF_SDK_GenericContainer_Binary.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_Binary.dylib.1.3.3
0x12148b000 - 0x1214abfff +com.adobe.VXMLPresetReader.framework 6.0.1 (6.0.1.0) <C9E8D8D6-9F0B-86EA-8ECA-D8EC8629BBE0> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/VXMLPresetReader.framework/VXMLPresetRead er
0x1214e6000 - 0x1215eefef +com.mainconcept.mc.enc.mp2v 9.1 (9.1.6.7339) <B02A0C50-AB7E-B512-52D7-2BDB1C1573C2> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/9/mc_enc_m p2v
0x121640000 - 0x1216f6fe3 +com.mainconcept.mc.mux.mp2 9.1 (9.1.6.7339) <044A2A73-237E-1E1B-F879-B1AE42814501> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/9/mc_mux_mp 2
0x121718000 - 0x1217bcfff +com.adobe.IPPMPEGDecoder.framework 6.0.1 (6.0.1.0) <AAE165B9-FEF4-ADBD-0D0A-9B8E075B2747> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMP EGDecoder
0x1217f3000 - 0x121815fff +com.adobe.ImporterFastMPEG.framework 6.0.1 (6.0.1.0) <F328E2BD-9822-984F-34C2-969F7A75EEA9> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/ImporterFastMPEG.bundle/Contents/Mac OS/ImporterFastMPEG
0x121844000 - 0x1218f6fe3 +com.mainconcept.mc.mfimport 9.1 (9.1.6.7339) <CD59C8E3-4EB4-C35D-599A-DC92B2D84E50> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/mc_mfimport.framework/Versions/9/mc_mfimp ort
0x1218ff000 - 0x12193eff7 +com.adobe.ImporterXDCAMEX.framework 6.0.1 (6.0.1.0) <B3D02434-0D0A-7FF0-E825-0058ADE613E8> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/ImporterXDCAMEX.bundle/Contents/MacO S/ImporterXDCAMEX
0x121991000 - 0x121a30ff7 +com.adobe.ImporterXDCAMHD.framework 6.0.1 (6.0.1.0) <BFE67CDB-368F-DE66-C980-6AC29B1DFE9D> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/ImporterXDCAMHD.bundle/Contents/MacO S/ImporterXDCAMHD
0x121aca000 - 0x121c7efe7 +com.mainconcept.mc.dec.mp2v 9.1 (9.1.6.7339) <FEDF523A-E855-CAB6-8AE2-579CFF7DEE54> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/9/mc_dec_m p2v
0x121c87000 - 0x121cf2fef +com.adobe.AVCIntraDecoder.framework 6.0.1 (6.0.1.0) <60668F93-C390-C88D-0D16-EABA670B7B34> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AVCIntraDecoder.framework/Versions/A/AVCI ntraDecoder
0x121d26000 - 0x121f12fef +libMXF_SDK.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK.dylib.4.4. 3
0x122094000 - 0x1220a2fff +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_JPEG2000.dylib.4.4.3
0x1220ae000 - 0x1220b8fe7 +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_ESAudio.dylib.4.4.3
0x1220c1000 - 0x1220d1fff +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEG2Video.dylib.4.4.3
0x1220de000 - 0x1220f1ff7 +libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEG4.dylib.4.4.3
0x1220fc000 - 0x122107fff +libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEGTS.dylib.4.4.3
0x12210f000 - 0x122118fff +libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_SystemScheme1.dylib.4.4.3
0x122121000 - 0x122132fff +libMXF_SDK_GenericContainer_Wave.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_Wave.dylib.4.4.3
0x122142000 - 0x12214dfff +libMXF_SDK_Metadata_RP224.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_Metadata_R P224.dylib.4.4.3
0x122154000 - 0x122165ff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetada ta_BinaryLoader.dylib.4.4.3
0x122175000 - 0x12218dffb +libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetada ta_XSDLoader.dylib.4.4.3
0x12219e000 - 0x1221c0ff8 +libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetada ta_XSDLoader2.dylib.4.4.3
0x1221d8000 - 0x1221e4ffa +libMXF_SDK_XMLUtils.dylib.4.4.3 ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_XMLUtils.d ylib.4.4.3
0x1221ee000 - 0x1221fdff7 +libMXF_SDK_GenericContainer_AIFF.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AIFF.dylib.1.3.3
0x122209000 - 0x122215fff +libMXF_SDK_GenericContainer_Blind.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_Blind.dylib.1.3.3
0x12221e000 - 0x12224bff8 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_AVC.dylib.1.3.3
0x122263000 - 0x122271fff +libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MP4.dylib.1.3.3
0x12227a000 - 0x122288fff +libMXF_SDK_GenericContainer_VC3.dylib.1.3.3 1.3.3 (compatibility 1.3.3) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_VC3.dylib.1.3.3
0x122294000 - 0x1222c5ff3 +libMXF_SDK_XMLBuilder.dylib.1.3.3 1.3.3 (compatibility 1.3.3) <73E5E3AE-A51C-D3F8-B036-433778DB90BD> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_XMLBuilder .dylib.1.3.3
0x1222e9000 - 0x1225b5ff6 +libxerces-c-3.0.dylib ??? (???) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libxerces-c-3.0.dylib
0x122752000 - 0x122b27fef +libxqilla.5.dylib 6.0.0 (compatibility 6.0.0) /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libxqilla.5.dylib
0x122dee000 - 0x122e30fff +com.adobe.ImporterQuickTime.framework 6.0.1 (6.0.1.0) <C4B30B06-3A55-C042-BE1A-59CFD9988839> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Plug-ins/Common/ImporterQuickTime.bundle/Contents/Ma cOS/ImporterQuickTime
0x122efe000 - 0x122f78fef +com.adobe.adobe_caps adobe_caps 6.0.29.0 (6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x122f97000 - 0x122fddfff +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 6.0.0.24 (6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A /UpdaterNotifications
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) <DB8B8AB0-0C97-B51C-BE8B-B79895735A33> /usr/lib/dyld
0x7fff80003000 - 0x7fff8004cfef libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x7fff8004d000 - 0x7fff800ccfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff801d9000 - 0x7fff809e3fe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <2F26CDC7-DAE9-9ABE-6806-93BBBDA20DA0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x7fff809e4000 - 0x7fff80a44fe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff80a45000 - 0x7fff80c06fef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff80c07000 - 0x7fff80c2afff com.apple.opencl 12.3.6 (12.3.6) <534AD81C-32AB-4C9A-5E0E-D6C6E77FA946> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff80c2b000 - 0x7fff80c46ff7 com.apple.openscripting 1.3.1 (???) <DC329CD4-1159-A40A-A769-70CAA70F601A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x7fff80c47000 - 0x7fff80c6eff7 libJPEG.dylib ??? (???) <32EDAB18-08ED-B31A-D2BD-12EFFE60D83C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff81d6b000 - 0x7fff81d84fff com.apple.CFOpenDirectory 10.6 (10.6) <11FAE9D5-6BD2-D302-96B0-2E135049CAA7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff81d85000 - 0x7fff81dbffff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <539EBFDD-96D6-FB07-B128-40232C408757> /usr/lib/libcups.2.dylib
0x7fff81dc0000 - 0x7fff820f4fef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff82266000 - 0x7fff822b0ff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x7fff822e3000 - 0x7fff822e8ff7 com.apple.CommonPanels 1.2.4 (91) <8B088D78-E508-6622-E477-E34C22CF2F67> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x7fff822e9000 - 0x7fff824a7fff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
0x7fff824ba000 - 0x7fff8258efe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8258f000 - 0x7fff825cdfe7 libFontRegistry.dylib ??? (???) <395D7C0D-36B5-B353-0DC8-51ABC0B1C030> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff826d1000 - 0x7fff826e7fe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x7fff826e8000 - 0x7fff82a85fe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff82a86000 - 0x7fff82a9cfef libbsm.0.dylib ??? (???) <0321D32C-9FE1-3919-E03E-2530A0C1191B> /usr/lib/libbsm.0.dylib
0x7fff82ae7000 - 0x7fff82b23fe7 libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <0109956D-D962-1736-B510-DC294F530E07> /usr/lib/libcurl.4.dylib
0x7fff82bdc000 - 0x7fff82bfcff7 com.apple.DirectoryService.Framework 3.6 (621.14) <15CF4C96-372D-C706-A237-47D20D2CAA6B> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x7fff83134000 - 0x7fff83146fe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <30FE378B-99FE-8C7C-06D0-A3AA0A0A70D4> /usr/lib/libsasl2.2.dylib
0x7fff83147000 - 0x7fff8314aff7 libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x7fff8314b000 - 0x7fff8317eff7 libTrueTypeScaler.dylib ??? (???) <B7BA8104-FA18-39A2-56E1-922EE7A660AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff8340a000 - 0x7fff83496fef SecurityFoundation ??? (???) <92FAC546-34A0-E65F-05DE-8883D7FECBA4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x7fff834ad000 - 0x7fff8358aff7 com.apple.vImage 4.1 (4.1) <A0DE28F5-7B45-D268-0497-C79A826C8E53> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x7fff8358b000 - 0x7fff8358bff7 com.apple.Carbon 150 (152) <F31CA1DA-A54B-FEDC-2101-5E902A36DA6F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8358c000 - 0x7fff835cfff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff836a9000 - 0x7fff837defff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x7fff837df000 - 0x7fff8388ffff edu.mit.Kerberos 6.5.11 (6.5.11) <CDA011E3-18C9-1573-3A31-497404CD6675> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff83917000 - 0x7fff83926fff com.apple.NetFS 3.2.2 (3.2.2) <84419796-36C9-DDCF-5FD1-0C96499EB63E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff83927000 - 0x7fff83928ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff83929000 - 0x7fff83a0efef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x7fff83a53000 - 0x7fff83b09ff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff83b13000 - 0x7fff83badfff com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x7fff83c0e000 - 0x7fff83c39ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib
0x7fff83c3a000 - 0x7fff83c90fff libTIFF.dylib ??? (???) <31FA0318-105B-9E11-B4D4-246BFD5B18E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff83cb5000 - 0x7fff83cb7fff libRadiance.dylib ??? (???) <B422DA26-E0CF-F280-6EB4-3B8FEF59B665> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff83ce8000 - 0x7fff83d34fff libauto.dylib ??? (???) <328CCF97-091D-C529-E576-C78583445711> /usr/lib/libauto.dylib
0x7fff83d84000 - 0x7fff83e39fe7 com.apple.ink.framework 1.3.3 (107) <A68339AA-909D-E46C-35C0-72808EE3D043> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x7fff83f2a000 - 0x7fff83f71ff7 com.apple.coreui 2 (114) <31118426-355F-206A-65AB-CCA2D2D3EBD7> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff83fcc000 - 0x7fff83fe0ff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <574C1BE0-5E5E-CCAF-06F8-92A69CB2892D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff83fe1000 - 0x7fff84022fef com.apple.QD 3.36 (???) <04F03722-91CA-6858-55A4-54D7F29789A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x7fff84d5f000 - 0x7fff84d73fff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x7fff84d74000 - 0x7fff84ffdff7 com.apple.security 6.1.2 (55002) <0D80504C-9A6D-C865-AF37-7C231ACF97CB> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff84ffe000 - 0x7fff84ffffff liblangid.dylib ??? (???) <D0666597-B331-C43C-67BB-F2E754079A7A> /usr/lib/liblangid.dylib
0x7fff85031000 - 0x7fff8516ffff com.apple.CoreData 102.1 (251) <96C5E9A6-C28C-E9CC-A0DB-27801A22A49F> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8521c000 - 0x7fff85271ff7 com.apple.framework.familycontrols 2.0.2 (2020) <1E8D193F-3236-59AB-2242-14AD94128E81> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x7fff85272000 - 0x7fff852affff com.apple.LDAPFramework 2.0 (120.1) <E5FA9339-4812-E8FE-C366-EE3DC975DBC6> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff852b0000 - 0x7fff852b2fff com.apple.print.framework.Print 6.1 (237.1) <87A5BEEC-2D37-5CB7-8B13-7B605397573F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x7fff85425000 - 0x7fff85425ff7 com.apple.Cocoa 6.6 (???) <C69E895A-1C66-3DA9-5F63-8BE85DB9C4E1> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff855fd000 - 0x7fff85682ff7 com.apple.print.framework.PrintCore 6.3 (312.7) <F00C561F-D38B-8785-5218-1A0C3BA61177> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff85683000 - 0x7fff85981fff com.apple.HIToolbox 1.6.5 (???) <98FCEA0D-FA33-E859-B39C-2C1F59F9E22D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x7fff85a0d000 - 0x7fff85a1cfef com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff85e04000 - 0x7fff85e57ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x7fff85eae000 - 0x7fff85ec5fff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x7fff85ec6000 - 0x7fff85eccff7 com.apple.DiskArbitration 2.3.1 (2.3.1) <FD5CF2E6-E5FF-1E2A-37E0-304722DA15E1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x7fff85ecd000 - 0x7fff86310fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <57D38705-6F21-2A82-F3F6-03CFFF214775> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff86316000 - 0x7fff86365ff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <066A477D-C16C-A6FD-718F-0CE8D39807DE> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0x7fff8656c000 - 0x7fff8656cff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x7fff86648000 - 0x7fff8665dff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <59D9E83D-3131-91F4-E3E2-02047F55917F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8665e000 - 0x7fff86699fff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x7fff86e2f000 - 0x7fff8752bff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8752c000 - 0x7fff8756dfff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x7fff875b0000 - 0x7fff875d1fe7 libPng.dylib ??? (???) <A6BF1360-1B23-78BD-12EF-E4A5753EEB76> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff875d2000 - 0x7fff875d2ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff875d3000 - 0x7fff8761bff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x7fff87666000 - 0x7fff87785fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff87786000 - 0x7fff877a7fff libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
0x7fff877a8000 - 0x7fff877adfff libGIF.dylib ??? (???) <3FD1157B-C002-5268-DEF4-70DDC40E6EDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff87884000 - 0x7fff87945fef com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff87aa9000 - 0x7fff87bc3fff libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x7fff87bfb000 - 0x7fff87bffff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x7fff87c00000 - 0x7fff87c04ff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff87c05000 - 0x7fff87c6ffe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <7BD7F19B-ACD4-186C-B42D-4DEBA6795628> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x7fff87c70000 - 0x7fff880b7fef com.apple.RawCamera.bundle 3.7.1 (570) <5AFA87CA-DC3D-F84E-7EA1-6EABA8807766> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x7fff88104000 - 0x7fff881bdfff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <E8FFCEA1-3BE3-F0C9-07EA-C37678C4D2F5> /usr/lib/libsqlite3.dylib
0x7fff884f9000 - 0x7fff884fcff7 com.apple.securityhi 4.0 (36638) <4497AC9D-4AD5-5155-B8B8-D47E694613A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x7fff88821000 - 0x7fff8889efef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff8889f000 - 0x7fff888aaff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <C359B93B-CC9B-FC0B-959E-FB10674103A7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x7fff888db000 - 0x7fff88b5dfff com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff88b5e000 - 0x7fff88b5fff7 com.apple.TrustEvaluationAgent 1.1 (1) <A91CE5B9-3C63-5F8C-5052-95CCAB866F72> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x7fff88b60000 - 0x7fff88b66ff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff88b67000 - 0x7fff88ba4ff7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <F743389F-F25A-A77D-4FCA-D6B01AF2EE6D> /usr/lib/libssl.0.9.8.dylib
0x7fff88ba5000 - 0x7fff88baafff libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x7fff88bab000 - 0x7fff88c3bfff com.apple.SearchKit 1.3.0 (1.3.0) <45BA1053-9196-3C2F-2421-AFF5E09627CC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x7fff88c3c000 - 0x7fff89636ff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8965f000 - 0x7fff896fffff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff89700000 - 0x7fff89700ff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff89701000 - 0x7fff89817ff7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib
0x7fff8994d000 - 0x7fff89972ff7 com.apple.CoreVideo 1.6.2 (45.6) <31802A1C-81BC-33F8-D5C8-39A793D4D926> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff89973000 - 0x7fff89a30fff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x7fff89cb4000 - 0x7fff89cbbfff com.apple.OpenDirectory 10.6 (10.6) <13CECF72-D84B-2A88-CB0C-2092FDF0DB5D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x7fff89ef7000 - 0x7fff89ef7ff7 com.apple.CoreServices 44 (44) <616722B1-5E79-DCCF-BF5E-0DD5802CCBD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x7fff89f6a000 - 0x7fff89f6dfff com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x7fff89f6e000 - 0x7fff89f7bfe7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff89f7c000 - 0x7fff89fbffef libtidy.A.dylib ??? (???) <C32D1061-EF58-9DE1-6D6E-1286E58B83EB> /usr/lib/libtidy.A.dylib
0x7fff8a129000 - 0x7fff8a151fff com.apple.DictionaryServices 1.1.2 (1.1.2) <6B8C5FB6-FE6F-3345-0441-BED51E815379> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8a1ef000 - 0x7fff8a26dff7 com.apple.CoreText 151.12 (???) <5BE797B7-C903-B664-ADD9-7514B1A6EF9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x7fff8a26e000 - 0x7fff8a330fe7 libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8a34d000 - 0x7fff8a4c4fe7 com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x7fff8a4e0000 - 0x7fff8a511fff libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x7fff8a512000 - 0x7fff8a512ff7 com.apple.ApplicationServices 38 (38) <0E2FC75E-2BE2-D04D-CA78-76E38A89DD30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x7fff8a513000 - 0x7fff8a524ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <5BAFAE5C-2307-C27B-464D-582A10A6990B> /usr/lib/libz.1.dylib
0x7fff8a5b5000 - 0x7fff8a774fff com.apple.ImageIO.framework 3.0.5 (3.0.5) <175E97F1-B1A7-655A-F154-5B6ACC5F3985> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8a775000 - 0x7fff8a783ff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff8a7bd000 - 0x7fff8a7c3ff7 IOSurface ??? (???) <27E523B3-6BE6-7D7D-5002-2A0E7ED2DB3D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
