I have an XML that is keeping a few scores. ( 5 entries ).
I need a Flash interface to be able to edit these nodes and save the XML back to the server.
Has anyone done anything like this ? I am open to using PHP with it to make it work.
Any guidance with this is appreciated.
Exactly you need a server side language to do it, PHP is good option.
You need save the scores to a database (using PHP) then load the data from the Data base (using PHP) in a XML format
To call the PHP files from Flash use URLLoader
http://library.creativecow.net/articles/brimelow_lee/php_mysql.php
If you search Google using terms like "AS3 save xml file" you should find plenty of info.
Hi
You can find a Tutorial and Source Code here: http://thefeldkircher.org/2010/11/04/xmlles/
Hope it helps
