Big ANE causes java.lang.OutOfMemoryError when packaging Air application
Aug 10, 2012 2:16 PM
Tags: #air #adobe #flash_builder #android #mobile #extension #ane #adt #apk #native #native_extensions #flash_builder_4.6 #dx
I'm working on an Air mobile game that uses ANE on iOS and Android. I'm in the process of creating a new ANE and face a problem on the Android side.
My ANE requires an external framework (Burstly, http://burstly.com). If I just link the Android project to Burstly's .jar file, I get errors in "adb logcat", like:
I/dalvikvm(16074): Could not find method com.burstly.lib.BurstlySdk.init, referenced from method com.freshplanet.burstly.functions.InitBurstlyFunction.call
In order to include Burstly's files in my own .jar, I unzip Burstly's .jar file and repackage them with my compiled code in a unique .jar (following advice on http://stackoverflow.com/questions/7732742/air-3-native-extensions-for -android-can-i-how-to-include-3rd-party-libraries).
Problem: Burstly's SDK includes thousands of files. It doesn't create any trouble when packaging the ANE, but when I try to package the Air application, I get the following error:
dx tool failed:
UNEXPECTED TOP-LEVEL ERROR:
java.lang.OutOfMemoryError: Java heap space
          at com.android.dx.util.IntList.<init>(IntList.java:87)
          at com.android.dx.rop.code.RopMethod.calcPredecessors(RopMethod.java:174 )
          at com.android.dx.rop.code.RopMethod.labelToPredecessors(RopMethod.java: 95)
          at com.android.dx.ssa.back.IdenticalBlockCombiner.process(IdenticalBlock Combiner.java:74)
          at com.android.dx.ssa.back.SsaToRop.convert(SsaToRop.java:132)
          at com.android.dx.ssa.back.SsaToRop.convertToRopMethod(SsaToRop.java:76)
          at com.android.dx.ssa.Optimizer.optimize(Optimizer.java:103)
          at com.android.dx.ssa.Optimizer.optimize(Optimizer.java:74)
          at com.android.dx.dex.cf.CfTranslator.processMethods(CfTranslator.java:2 69)
          at com.android.dx.dex.cf.CfTranslator.translate0(CfTranslator.java:131)
          at com.android.dx.dex.cf.CfTranslator.translate(CfTranslator.java:85)
          at com.android.dx.command.dexer.Main.processClass(Main.java:299)
          at com.android.dx.command.dexer.Main.processFileBytes(Main.java:278)
          at com.android.dx.command.dexer.Main.access$100(Main.java:56)
          at com.android.dx.command.dexer.Main$1.processFileBytes(Main.java:229)
          at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpen er.java:244)
          at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.j ava:130)
          at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java :108)
          at com.android.dx.command.dexer.Main.processOne(Main.java:247)
          at com.android.dx.command.dexer.Main.processAllFiles(Main.java:183)
          at com.android.dx.command.dexer.Main.run(Main.java:139)
          at com.android.dx.command.dexer.Main.main(Main.java:120)
          at com.android.dx.command.Main.main(Main.java:89)
I read that the solution to eliminate this error is to give Java the parameters "-Xms...M -Xmx...M", with "..." being a high-enough number. Note that I'm working on a machine with 8GB of RAM. I tried to package the app in command line to be able to pass these parameters:
/usr/bin/java -Xms512M -Xmx4096M -jar "/Applications/Adobe Flash Builder 4.6/sdks/4.6.0air31/lib/adt.jar" -package -target apk -storetype pkcs12 -keystore [...].p12 Main.apk Main-app.xml Main.swf -extdir "/Users/alex/Documents/Adobe Flash Builder 4.6/.metadata/.plugins/com.adobe.flexbuilder.project.ui/ANEFiles/fron t-end-mobile/com.adobe.flexide.multiplatform.ios.platform"
But when I run a "ps -ef | grep java", I can see that adt runs another Java program (dx) without transmitting my -Xms -Xmx parameters:
/usr/bin/java -jar /Applications/Adobe Flash Builder 4.6/sdks/4.6.0air31/lib/android/bin/dx.jar --dex --output=/private/var/folders/t9/3kw74cx14nv2xg9tgmx9m1jc0000gp/T/b57 57d93-1e93-439c-8f6d-c93e4933f6f1/outputDEX.dex [... bunch of jars]
Any idea to solve this issue?
Alex
