zwickl
Adding Metadata to PDF Form
Feb 4, 2011 11:09 AM
Hi, I'm trying to add some metadata to a pdf. I have the follow script in the form initialize event:
if (form1.desc.nodes.namedItem("metadata") == null) then
var oNode=xfa.form.createNode("text", "metadata")
form1.desc.nodes.append(oNode)
endif
I receive the error message:
Argument mismatch in property or function argument
I also tried this code:
oNode.value = "Test Data"
endif
Which gave me this error:
accessor "oNode.value" is unknown
It appears that the oNode object is not being created.
Any suggesting how I can add Metadata to the PDF?
    Feb 5, 2011 7:42 PM   in reply to zwickl
    I don't use FormCalc a great deal, the following equivilent in JavaScript seems to work;
    Bruce
    Aug 10, 2012 3:19 PM   in reply to zwickl
    Bruce / Zwicki - or anyone who can assit...
    How did you get this to work?
    I'm looking for a way to add/inject values (keywords) into the form's meta-data by retrieving the values from user input.
    To test the above solution, I added the following script to the initialize event as referenced, but I'm not sure what is happening:
    1. Do I need a field on the page?
    2. What part of the above script affects the meta-data?
    Aug 13, 2012 1:33 AM   in reply to SI_MSD7
    Hi,If you mean metadata like those set in the Form Properties Info tab, I don't think you can do this at run time, the above code is more like a form variable. Regards Bruce
