Charken32
Problems installing adobe AIR
Aug 10, 2012 4:46 PM
I'm having problems installing Adobe AIR. The installer launches two processes but nothing happens after that. I'm using a windows 7 pc.
Here is the install log I found:
[2010-09-16:16:41:49] Performing runtime update
[2010-09-16:16:41:49] UI SWF load is complete
[2010-09-16:16:41:50] UI initialized
[2010-09-16:16:41:50] starting user confirmation
[2010-09-16:16:41:50] Version of this installer: 2.0.3.13070
[2010-09-16:16:41:50] Installed version: 1.5.2.8870
[2010-09-16:16:41:50] Installation type: patchNewer
[2010-09-16:16:41:53] starting elevated install
[2010-09-16:16:41:54] performing an elevated runtime install
[2010-09-16:16:41:54] UI SWF load is complete
[2010-09-16:16:41:54] starting install
[2010-09-16:16:41:54] subinstaller: starting install
[2010-09-16:16:41:54] Scheduling runtime installation operations
[2010-09-16:16:41:54] subinstaller: Scheduling runtime installation operations
[2010-09-16:16:41:54] Active AIR product GUID is {A2BCA9F1-566C-4805-97D1-7FDC93386723}
[2010-09-16:16:41:54] subinstaller: Active AIR product GUID is {A2BCA9F1-566C-4805-97D1-7FDC93386723}
[2010-09-16:16:41:54] Scheduling an MSI install operation
[2010-09-16:16:41:54] subinstaller: Scheduling an MSI install operation
[2010-09-16:16:41:54] Beginning runtime installation
[2010-09-16:16:41:54] subinstaller: Beginning runtime installation
[2010-09-16:16:41:54] Beginning install
[2010-09-16:16:41:54] subinstaller: Beginning install
[2010-09-16:16:41:54] Installing c:\users\risto\appdata\local\temp\aird75b.tmp\setup.msi
[2010-09-16:16:41:54] subinstaller: Installing c:\users\risto\appdata\local\temp\aird75b.tmp\setup.msi
[2010-09-16:16:41:55] Copying C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe to C:\Users\Risto\AppData\Local\Temp\flaF4BA.tmp\temp
[2010-09-16:16:41:55] subinstaller: Copying C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe to C:\Users\Risto\AppData\Local\Temp\flaF4BA.tmp\temp
[2010-09-16:16:41:55] Deleting C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe
[2010-09-16:16:41:55] subinstaller: Deleting C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe
[2010-09-16:16:41:55] Copying C:\Users\Risto\appdata\local\temp\aird75b.tmp\Adobe AIR\Versions\1.0\Resources\airappinstaller.exe to C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe
[2010-09-16:16:41:55] subinstaller: Copying C:\Users\Risto\appdata\local\temp\aird75b.tmp\Adobe AIR\Versions\1.0\Resources\airappinstaller.exe to C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe
[2010-09-16:16:41:55] Copying C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\digest.s to C:\Users\Risto\AppData\Local\Temp\flaF4DA.tmp\temp
[2010-09-16:16:41:55] subinstaller: Copying C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\digest.s to C:\Users\Risto\AppData\Local\Temp\flaF4DA.tmp\temp
[2010-09-16:16:41:55] Deleting C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\digest.s
[2010-09-16:16:41:55] subinstaller: Deleting C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\digest.s
[2010-09-16:16:41:55] Copying C:\Users\Risto\appdata\local\temp\aird75b.tmp\Adobe AIR\Versions\1.0\Resources\digest.s to C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\digest.s
[2010-09-16:16:41:55] subinstaller: Copying C:\Users\Risto\appdata\local\temp\aird75b.tmp\Adobe AIR\Versions\1.0\Resources\digest.s to C:\Users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\digest.s
[2010-09-16:16:41:55] Execution complete; beginning commit phase
[2010-09-16:16:41:55] subinstaller: Execution complete; beginning commit phase
[2010-09-16:16:41:55] Deleting C:\Users\Risto\AppData\Local\Temp\flaF4BA.tmp\temp
[2010-09-16:16:41:55] subinstaller: Deleting C:\Users\Risto\AppData\Local\Temp\flaF4BA.tmp\temp
[2010-09-16:16:41:55] Deleting C:\Users\Risto\AppData\Local\Temp\flaF4DA.tmp\temp
[2010-09-16:16:41:55] subinstaller: Deleting C:\Users\Risto\AppData\Local\Temp\flaF4DA.tmp\temp
[2010-09-16:16:41:55] Commit complete
[2010-09-16:16:41:55] subinstaller: Commit complete
[2010-09-16:16:41:55] install complete
[2010-09-16:16:41:55] subinstaller: install complete
[2010-09-16:16:41:55] begin quitting
[2010-09-16:16:41:55] subinstaller: begin quitting
[2010-09-16:16:41:55] Elevated install completed
[2010-09-16:16:41:57] begin quitting
[2010-09-16:16:44:19] UI SWF load is complete
[2010-09-16:16:44:20] UI initialized
[2010-09-16:16:44:20] Pingback request completed with HTTP status 200
[2010-09-16:16:44:20] Begin background update check
[2010-09-16:16:44:20] Starting download from http://airdownload.adobe.com/air/3/background/windows/x86/patch/2.0.3. 13070/update
[2010-09-16:16:44:21] Background update not available
[2010-09-16:16:44:21] begin quitting
[2010-09-16:16:45:16] UI SWF load is complete
[2010-09-16:16:45:17] UI initialized
[2010-09-16:16:45:17] Pingback request completed with HTTP status 200
[2010-09-16:16:45:17] Begin background update check
[2010-09-16:16:45:17] Starting download from http://airdownload.adobe.com/air/3/background/windows/x86/patch/2.0.3. 13070/update
[2010-09-16:16:45:18] Background update not available
[2010-09-16:16:45:18] begin quitting
[2010-09-16:16:45:40] UI SWF load is complete
[2010-09-16:16:45:41] UI initialized
[2010-09-16:16:45:41] Pingback request completed with HTTP status 200
[2010-09-16:16:45:41] Begin background update check
[2010-09-16:16:45:41] Starting download from http://airdownload.adobe.com/air/3/background/windows/x86/patch/2.0.3. 13070/update
[2010-09-16:16:45:41] Background update not available
[2010-09-16:16:45:41] begin quitting
[2010-09-16:20:26:41] UI SWF load is complete
[2010-09-16:20:26:41] UI initialized
[2010-09-16:20:26:42] Pingback request completed with HTTP status 200
[2010-09-16:20:26:42] Begin background update check
[2010-09-16:20:26:42] Starting download from http://airdownload.adobe.com/air/3/background/windows/x86/patch/2.0.3. 13070/update
[2010-09-16:20:26:43] Background update not available
[2010-09-16:20:26:44] begin quitting
[2010-12-05:19:15:11] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2010-12-05:19:15:12] Commandline is: -silent
[2010-12-05:19:15:12] Installed runtime (2.0.3.13070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2010-12-05:19:15:12] Starting silent runtime update. Updating runtime from version 2.0.3.13070 to version 2.5.1.17730
[2010-12-05:19:15:12] Installing msi at c:\users\risto\appdata\local\temp\air65bb.tmp\setup.msi with guid {46C045BF-2B3F-4BC4-8E4C-00E0CF8BD9DB}
[2010-12-05:19:15:14] Runtime Installer end with exit code 0
[2010-12-05:19:15:16] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2010-12-05:19:15:16] Commandline is: -silent -location "C:\Program Files (x86)\Voddler" "C:\Program Files (x86)\Voddler\VoddlerPlayer.air"
[2010-12-05:19:15:16] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2010-12-05:19:15:16] Invoking Application Installer for combined install
[2010-12-05:19:15:16] Launching subprocess with commandline C:\Users\Risto\AppData\Local\Temp\AIR78BE.tmp\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime C:\Users\Risto\AppData\Local\Temp\AIR78BE.tmp -silent -withRuntime -url -location "C:\Program Files (x86)\Voddler" file:///C:/Program%20Files%20(x86)/Voddler/VoddlerPlayer.air
[2010-12-05:19:15:17] Application Installer begin with version 2.5.1.17730 on Windows 7 x86
[2010-12-05:19:15:17] Commandline is: -runtime C:\Users\Risto\AppData\Local\Temp\AIR78BE.tmp -silent -withRuntime -url -location "C:\Program Files (x86)\Voddler" file:///C:/Program%20Files%20(x86)/Voddler/VoddlerPlayer.air
[2010-12-05:19:15:17] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2010-12-05:19:15:17] Unpackaging file:///C:/Program%20Files%20(x86)/Voddler/VoddlerPlayer.air to C:\Users\Risto\AppData\Local\Temp\fla83C6.tmp
[2010-12-05:19:15:18] Application signature verified
[2010-12-05:19:15:18] Unpackaging/validation complete
[2010-12-05:19:15:18] No app located for appID 'VoddlerPlayer' and pubID '22AA32E1C519F8FB77514A36DC6C2AE2C623240F.1'
[2010-12-05:19:15:18] Converting unpackaged application to a native installation package in C:\Users\Risto\AppData\Local\Temp\fla878E.tmp
[2010-12-05:19:15:18] Native installation package creation succeeded
[2010-12-05:19:15:18] Starting silent app installation to C:\Program Files (x86)\Voddler. Installing app VoddlerPlayer.22AA32E1C519F8FB77514A36DC6C2AE2C623240F.1 version 3.1 using the source file at file:///C:/Program%20Files%20(x86)/Voddler/VoddlerPlayer.air
[2010-12-05:19:15:18] Installing msi at C:\Users\Risto\AppData\Local\Temp\fla878E.tmp\setup.msi with guid {F2D36F4C-F63E-9EB1-758A-CB33FC50E650}
[2010-12-05:19:15:19] Application Installer end with exit code 0
[2010-12-05:19:15:20] Subprocess app installer succeeded
[2010-12-05:19:15:20] Runtime Installer end with exit code 0
[2010-12-05:19:16:35] Launching subprocess with commandline c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -updatecheck
[2010-12-05:19:16:35] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2010-12-05:19:16:35] Commandline is: -updatecheck
[2010-12-05:19:16:35] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2010-12-05:19:16:35] Performing pingback request
[2010-12-05:19:16:37] Pingback request completed with HTTP status 200
[2010-12-05:19:16:37] Starting runtime background update check
[2010-12-05:19:16:37] Begin Background update download from http://airdownload.adobe.com/air/3/background/windows/x86/patch/2.5.1. 17730/update
[2010-12-05:19:16:37] Unpackaging http://airdownload.adobe.com/air/3/background/windows/x86/patch/2.5.1. 17730/update to C:\Users\Risto\AppData\Roaming\Adobe\AIR\Updater\Background
[2010-12-05:19:16:37] Runtime update not available
[2010-12-05:19:16:37] Unpackaging cancelled
[2010-12-05:19:16:37] Runtime Installer end with exit code 0
[2010-12-15:00:25:09] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2010-12-15:00:25:09] Commandline is: -uninstall
[2010-12-15:00:25:09] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2010-12-15:00:25:09] Starting runtime uninstall. Uninstalling runtime version 2.5.1.17730
[2010-12-15:00:25:09] Uninstalling product with GUID {46C045BF-2B3F-4BC4-8E4C-00E0CF8BD9DB}
[2010-12-15:00:25:11] Runtime Installer end with exit code 0
[2010-12-15:00:25:14] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2010-12-15:00:25:14] Commandline is: -silent
[2010-12-15:00:25:14] No installed runtime detected
[2010-12-15:00:25:14] Starting silent runtime install. Installing runtime version 2.5.1.17730
[2010-12-15:00:25:14] Installing msi at c:\users\risto\appdata\local\temp\air9ed9.tmp\setup.msi with guid {46C045BF-2B3F-4BC4-8E4C-00E0CF8BD9DB}
[2010-12-15:00:25:21] Runtime Installer end with exit code 0
[2011-11-10:15:14:19] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-11-10:15:14:19] Commandline is:
[2011-11-10:15:14:19] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-11-10:15:14:22] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-11-10:15:14:22] Commandline is:
[2011-11-10:15:14:22] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-11-10:15:14:26] Runtime Installer end with exit code 6
[2011-11-10:15:15:04] Runtime Installer end with exit code 6
[2011-11-10:15:15:12] Runtime Installer begin with version 3.0.0.4080 on Windows 7 x86
[2011-11-10:15:15:12] Commandline is:
[2011-11-10:15:15:12] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-11-10:15:19:27] Runtime Installer end with exit code 6
[2011-11-23:00:30:16] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2011-11-23:00:30:16] Commandline is: -arp:uninstall
[2011-11-23:00:30:16] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-11-23:00:30:18] Relaunching with elevation
[2011-11-23:00:30:18] Launching subprocess with commandline c:\program files (x86)\common files\adobe air\versions\1.0\resources\adobe air updater.exe -eu
[2011-11-23:00:30:18] Runtime Installer begin with version 2.5.1.17730 on Windows 7 x86
[2011-11-23:00:30:18] Commandline is: -stdio \\.\pipe\AIR_3356_0 -eu
[2011-11-23:00:30:18] Installed runtime (2.5.1.17730) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2011-11-23:00:30:18] Starting runtime uninstall. Uninstalling runtime version 2.5.1.17730
[2011-11-23:00:30:19] Uninstalling product with GUID {46C045BF-2B3F-4BC4-8E4C-00E0CF8BD9DB}
[2011-11-23:00:30:21] Runtime Installer end with exit code 0
[2011-11-23:00:30:21] Elevated install completed
[2011-11-23:00:35:41] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-23:00:35:41] Commandline is:
[2011-11-23:00:35:41] No installed runtime detected
[2011-11-23:00:35:57] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-23:00:35:57] Commandline is:
[2011-11-23:00:35:57] No installed runtime detected
[2011-11-23:00:36:15] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-23:00:36:15] Commandline is:
[2011-11-23:00:36:15] No installed runtime detected
[2011-11-23:00:36:58] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-23:00:36:58] Commandline is:
[2011-11-23:00:36:58] No installed runtime detected
[2011-11-23:00:36:59] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-23:00:36:59] Commandline is:
[2011-11-23:00:36:59] No installed runtime detected
[2011-11-24:20:54:19] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:20:54:20] Commandline is:
[2011-11-24:20:54:20] No installed runtime detected
[2011-11-24:20:55:19] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:20:55:19] Commandline is:
[2011-11-24:20:55:19] No installed runtime detected
[2011-11-24:20:56:08] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:20:56:08] Commandline is:
[2011-11-24:20:56:08] No installed runtime detected
[2011-11-24:20:56:10] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:20:56:10] Commandline is:
[2011-11-24:20:56:10] No installed runtime detected
[2011-11-24:20:56:23] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:20:56:23] Commandline is:
[2011-11-24:20:56:23] No installed runtime detected
[2011-11-24:20:56:24] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:20:56:24] Commandline is:
[2011-11-24:20:56:24] No installed runtime detected
[2011-11-24:21:10:50] Runtime Installer begin with version 3.1.0.4880 on Windows Vista x86
[2011-11-24:21:10:50] Commandline is:
[2011-11-24:21:10:50] No installed runtime detected
[2011-11-24:23:15:27] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-11-24:23:15:27] Commandline is:
[2011-11-24:23:15:27] No installed runtime detected
[2011-12-09:21:24:09] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-12-09:21:24:10] Commandline is:
[2011-12-09:21:24:10] No installed runtime detected
[2011-12-09:21:24:16] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-12-09:21:24:16] Commandline is:
[2011-12-09:21:24:16] No installed runtime detected
[2011-12-09:21:24:26] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-12-09:21:24:26] Commandline is:
[2011-12-09:21:24:26] No installed runtime detected
[2011-12-09:21:26:03] Runtime Installer begin with version 3.1.0.4880 on Windows 7 x86
[2011-12-09:21:26:03] Commandline is:
[2011-12-09:21:26:03] No installed runtime detected
[2011-12-09:21:26:53] Runtime Installer begin with version 3.1.0.4880 on Windows Vista x86
[2011-12-09:21:26:53] Commandline is:
[2011-12-09:21:26:53] No installed runtime detected
[2011-12-09:21:27:32] Runtime Installer begin with version 3.1.0.4880 on Windows Vista x86
[2011-12-09:21:27:32] Commandline is:
[2011-12-09:21:27:32] No installed runtime detected
[2011-12-09:21:28:19] Runtime Installer begin with version 3.1.0.4880 on Windows Vista x86
[2011-12-09:21:28:19] Commandline is:
[2011-12-09:21:28:19] No installed runtime detected
[2011-12-09:21:33:58] Runtime Installer begin with version 3.1.0.4880 on Windows Vista x86
[2011-12-09:21:33:58] Commandline is:
[2011-12-09:21:33:58] No installed runtime detected
[2011-12-09:21:57:26] Runtime Installer begin with version 3.1.0.4880 on Windows Vista x86
[2011-12-09:21:57:26] Commandline is:
[2011-12-09:21:57:26] No installed runtime detected
[2012-08-10:15:53:50] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:15:53:50] Commandline is:
[2012-08-10:15:53:50] No installed runtime detected
[2012-08-10:15:53:58] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:15:53:58] Commandline is:
[2012-08-10:15:53:58] No installed runtime detected
[2012-08-10:15:56:45] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:15:56:45] Commandline is:
[2012-08-10:15:56:45] No installed runtime detected
[2012-08-10:15:58:04] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:15:58:04] Commandline is:
[2012-08-10:15:58:04] No installed runtime detected
[2012-08-10:15:58:07] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:15:58:07] Commandline is:
[2012-08-10:15:58:07] No installed runtime detected
[2012-08-10:16:00:57] Runtime Installer begin with version 3.3.0.3670 on Windows 7 x86
[2012-08-10:16:00:57] Commandline is:
[2012-08-10:16:00:57] No installed runtime detected
[2012-08-10:16:01:03] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:01:03] Commandline is:
[2012-08-10:16:01:03] No installed runtime detected
[2012-08-10:16:01:54] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:01:54] Commandline is:
[2012-08-10:16:01:54] No installed runtime detected
[2012-08-10:16:10:15] Runtime Installer begin with version 3.3.0.3670 on Windows 7 x86
[2012-08-10:16:10:15] Commandline is:
[2012-08-10:16:10:15] No installed runtime detected
[2012-08-10:16:10:43] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:10:43] Commandline is:
[2012-08-10:16:10:43] No installed runtime detected
[2012-08-10:16:14:35] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:14:35] Commandline is:
[2012-08-10:16:14:35] No installed runtime detected
[2012-08-10:16:21:35] Runtime Installer begin with version 3.3.0.3670 on Windows 7 x86
[2012-08-10:16:21:35] Commandline is:
[2012-08-10:16:21:35] No installed runtime detected
[2012-08-10:16:22:54] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:22:54] Commandline is:
[2012-08-10:16:22:54] No installed runtime detected
[2012-08-10:16:25:56] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:25:56] Commandline is:
[2012-08-10:16:25:56] No installed runtime detected
[2012-08-10:16:31:00] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:31:00] Commandline is:
[2012-08-10:16:31:00] No installed runtime detected
[2012-08-10:16:32:44] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:32:44] Commandline is:
[2012-08-10:16:32:44] No installed runtime detected
[2012-08-10:16:33:12] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:33:12] Commandline is:
[2012-08-10:16:33:12] No installed runtime detected
[2012-08-10:16:35:26] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:35:26] Commandline is:
[2012-08-10:16:35:26] No installed runtime detected
[2012-08-10:16:39:01] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:39:01] Commandline is:
[2012-08-10:16:39:01] No installed runtime detected
[2012-08-10:16:41:51] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:16:41:51] Commandline is:
[2012-08-10:16:41:51] No installed runtime detected
[2012-08-10:16:51:25] Runtime Installer begin with version 3.3.0.3670 on Windows 7 x86
[2012-08-10:16:51:25] Commandline is:
[2012-08-10:16:51:25] No installed runtime detected
[2012-08-10:17:19:42] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-08-10:17:19:42] Commandline is:
[2012-08-10:17:19:42] No installed runtime detected
Any help would be appreciated.
