evarey77
Renaming batch files
Aug 10, 2012 10:19 PM
Tags: #cs4
I would like to automate of saving, renaming, closing open documents then placing them in a seperate folder after I'm done adding watermarks to my images. The problem I'm coming across is that the action i have renames all the files using the same name (whatever example/file I used when I recorded the action).,
So even though the original file names are 123.jpg, 124.jpg, 125.jpg and I want them to be renamed as 123c.jpg, 124c.jpg, 125c.jpg all of them gets renamed 122c.jpg.
I'm not sure how to do a screen shot, so here is the skinny on what I have done...
Under the Batch window I marked the following:
Play:      Set: Set1
              Action: Watermark Save & Exit
Source: Opened Files
Destination: Folder      Desktop/Watermarked Pictures
Override Action "Save As" Commands (box is checked)
File Naming: "Document Name+c+extension
Starting serial #1
Errors: Stop for Errors
Any ideas on what I did wrong??
I use CS4 if that matters.
Thanks!!
