hi , how are you all ?
i made game in 1 stage and it works without errors but i have problem and here are some pictures then i will insert the code
first there is 1 hero, and enemy .and 1 portal
when you touch the enemy it will hit you and you gonna lose hp until death
like here
[url=http://www.gulfup.com/show/X9e9628ecxzc4cw][img]http://im18.gulfup.com/2012-08-11/1344659217691.png[/img][/url]
but there is a portal that you can use it for kill the enemy (the pat )
here
[url=http://www.gulfup.com/show/Xs6ria103sf4gw][img]http://im18.gulfup.com/2012-08-11/1344659218552.png[/img][/url]
but the problem is : the enemy still hitting you ?? i dont know why ? i remove it and all its events
but it,s still in the stage ??
here is the code of the MAIN class and its placein document file
[url=http://www.gulfup.com/show/X9e9od31np68sgg][img]http://im17.gulfup.com/2012-08-11/1344660833131.png[/img][/url]
package {
import flash.display.MovieClip;
import flash.events.Event;
public class MAIN extends MovieClip {
public function MAIN() {
addEventListener(Event.ADDED_TO_STAGE,onAddedToStage)
public function onAddedToStage(event:Event):void
addEventListener(Event.ENTER_FRAME,onEnterFrame )
addEventListener(Event.REMOVED_FROM_STAGE,onRemovedFromStage)
private function onRemovedFromStage(event:Event):void
removeEventListener(Event.ENTER_FRAME, onEnterFrame);
removeEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
removeEventListener(Event.REMOVED_FROM_STAGE, onRemovedFromStage);
trace("player removed");
public function onEnterFrame (event:Event)
if (hero.hitTestObject(bat1))
healthbar1.width -=1
if (healthbar1.width >= 80 && healthbar1.width <= 100 ){
zelda1.gotoAndPlay(1)
if (healthbar1.width >= 60 && healthbar1.width <= 80){
zelda1.gotoAndPlay(2)
if (healthbar1.width >= 40 && healthbar1.width <= 60){
zelda1.gotoAndPlay(3)
if (healthbar1.width >= 20 && healthbar1.width <= 40){
zelda1.gotoAndPlay(4)
if (healthbar1.width >= 0 && healthbar1.width <= 20){
zelda1.gotoAndPlay(5)
if (hero.hitTestObject(portal2)){
var map2:MAP2 = new MAP2
addChild(map2)
if(map1.stage){
removeChild(map1)
if (hero.hitTestObject(portal3)){
var map4:BACKGROUND = new BACKGROUND
if(bat1.stage){
removeChild(bat1)
bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);
and here is the bat class
[url=http://www.gulfup.com/show/X34r84djied4w0s][img]http://im17.gulfup.com/2012-08-11/1344660833422.png[/img][/url]
package {
public class BAT1 extends MovieClip {
public function BAT1() {
trace("bat removed");
thats all , also iam sure about that(the pat has removed because i saw this in trace message)
bat1 removed
here
[url=http://www.gulfup.com/show/X9e9w762dv5cs4k][img]http://im18.gulfup.com/2012-08-11/1344661317721.png[/img][/url]
thank you
(yeah right the images dont work auto i dont know why , but you can just click it then it will work )
thanks again)
sorry i mean (bat removed) you can take a look at the last photo and it,s in the bat1 class
thank you for your replay
again, removing an object from the stage does not invalidate a hittest. your bat object still exists and it still has x,y properties etc.
you should probably clear your bat objects from memory and revamp your code so you're not testing objects that don't exist. but a quick fix would be to use:
if(hero.hitTestObject(bat1)&&bat1.stage)
