hiofgdshagilb
Program Monitor is white / unresponsive
Aug 11, 2012 10:53 AM
Tags: #monitor #program #white
Hi, I have a file that will not cooperate. Nothing shows up in my program monitor, it's all white. If I scrub the timeline in the sequence it's still unresponsive (the sound doesn't even scrub). Usually Premiere will end up crashing soon after.
My specs:
Premiere Pro CS5.5
Intel Core i7-3770 @ 3.40GHz
12 GB RAM
64 bit
    Aug 11, 2012 10:58 AM   in reply to hiofgdshagilb
    Give specs on the file.
    Aug 11, 2012 12:00 PM   in reply to hiofgdshagilb
    What codec and what are your project settings?
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    http://forums.adobe.com/thread/592070?tstart=30
    For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
    For Mac http://mediainspector.massanti.com/
    Also, more information about your hardware http://forums.adobe.com/message/4200840
    ESPECIALLY your brand/model graphis adapter (ATI or nVidia or ???) and the driver version number
    Aug 11, 2012 12:23 PM   in reply to hiofgdshagilb
    Also, what is the make/model of your video card?
    What is the number and date of your installed video driver?
    Good luck,
    Hunt
    Aug 11, 2012 11:01 PM   in reply to hiofgdshagilb
    We use .swf files (Adobe Flash exports) for 90% of our clips.
    Not the best option for source material.
    I'm not at all familiar with Flash, but if you can export a genuine video format, you may have better luck.
    Aug 12, 2012 3:32 AM   in reply to hiofgdshagilb
    You might want to move your project (and files?) of off the C-drive.
    Aug 12, 2012 10:22 AM   in reply to hiofgdshagilb
    Your single hard disk is like a single lane road, traffic is only allowed in one direction at a time. Traffic from the other side has to wait for the traffic light to change. Not very fast, is it. With a huge amount of traffic delays can be sizable. It is like the Gotthard tunnel on Black Saturday with huge traffic jams.
    Aug 12, 2012 11:03 AM   in reply to hiofgdshagilb
    >our work files or on our Dropbox folder
    I Googled, and a "Dropbox folder" is a cloud device... which I don't think will work, since it is "similar" to a network device
    Premiere will not work properly with a network
    -http://forums.adobe.com/thread/771151
    -http://forums.adobe.com/thread/851602
    -a work around, of sorts http://forums.adobe.com/thread/957523
    -and not on a "domain" http://forums.adobe.com/thread/858977
    Aug 12, 2012 1:55 PM   in reply to hiofgdshagilb
    hiofgdshagilb - "Premiere is buggy and crashes all the time"
    It sounds like you have some real system / work flow issues. Ive been running CS5.5 / 6 on a Mac  and CS6 on a PC since release with no crashes.
    Aug 12, 2012 2:32 PM   in reply to hiofgdshagilb
    it only exports massive avi files that take forever to render.
    Yes, try those instead.
    SWF files are designed for final delivery to be embedded in a web page.  AVI files using a supported codec are designed for editing.
    Aug 13, 2012 7:23 AM   in reply to hiofgdshagilb
    That is a "bullet," that most of us have to bite.
    There is a big difference in real-world editing between file formats/CODEC's, that will Import, and ones that will edit nicely.
    For instance, PrPro will Import WMV's, but their processing takes a lot of CPU cycles, and time. In the case of WMV's, I have found that converting to an AVI, that PrPro can handle nicely, ends up saving a lot of time, when editing and outputting - for me, well worth the extra step.
    Good luck,
    Hunt
    Aug 31, 2012 8:08 AM   in reply to hiofgdshagilb
    I'm getting the "White Screen - Not Responding" thing as well.
    Just wondering if you're still doing ok?
    Did the video card/driver re-install solve this for good for you?
    Did you first uninstall the drivers, then pull the physical card out?
    Then re-plug the card back in and install new drivers?
Bookmarked By (1)
